Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Engine smoke.. engine cuts out in 1st gear
I have white smoke comming from passenger side of the engine.. The engine cuts out for a second when I am starting to accelerate in 1st gear.
I am taking it to a tech in the morning, should I be okay to drive the 15miles to the shop? Also, any ideas on what it could be would be helpful.
Thanks!
Old 04-24-2008, 05:25 PM
I found the oil drip. I dont know exactly where its comming from though. The white smoke stops after about 10 min of running.
Old 04-24-2008, 05:26 PM
Super Moderator
nize's Avatar
check the cam cover gasket, especially in the rear area by the firewall. it's a common location for failure.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 04-25-2008, 11:29 AM
Is this a serious problem? And, is this the reason for my engine to be cutting out in 1st gear?
Old 04-25-2008, 08:42 PM
Super Moderator
nize's Avatar
is it a serious problem? read this thread;
engine fire ! damn !
and this thread;
fireproof fuel sleeves for fuel lines
1st gear cutout sounds unrelated.
Old 04-26-2008, 12:21 AM
Thanks alot!
What part should I buy? The "Camshaft housing gasket" ?
Old 04-26-2008, 10:26 PM
Super Moderator
nize's Avatar
first make sure that's where the oil is leaking from.
Old 04-27-2008, 12:58 AM
