Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Super Moderator
nize's Avatar
loctite 574
is available from pelican. apparently, it's important to use this when rebuilding the motor and the factory manual specifies this by name;
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 04-23-2008, 10:23 AM
Nobody Special
Just make sure you have a fresh bottle. It cures anerobically and is pretty sensitive to shelf life. It's also good to have a tube of Curil 'T' also for the ends caps on the balance shaft housings and the corners of the oil pan when you bolt it all up.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 04-23-2008, 11:33 AM
I'll be doing my oil pan in a couple of weeks, is Curil 'T' generally available or is it one of those items I should just order online?
1987 951 ROW
Old 04-23-2008, 12:41 PM
Super Moderator
nize's Avatar
i haven't even been able to find that. where is it sold/listed?
Old 04-23-2008, 12:44 PM
Super Moderator
nize's Avatar
aha! found it;
also available right on here from pelican !
Old 04-23-2008, 12:52 PM
Thanks Peter! It was hiding right under my nose!
1987 951 ROW
Old 04-24-2008, 05:59 AM
