-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Just Picked up my 951S: drives like a slug: suggestions on what's wrong?? (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/416106-just-picked-up-my-951s-drives-like-slug-suggestions-whats-wrong.html)
MarkRobinson 06-23-2008 07:40 AM
Ok, picked up my turbo S: here's my impressions:
Clean emissions test, decent (24mpg @ 80mpg) gas mileage (1000 miles of driving this weekend). Ran injector cleaner through it on 1/2 tanks to help remove some of the gas separation, evident from the odd readings during times, on the gas level indicator.
Car does NOT want to "go" from a stop: acts like a heavy 944 until you hold the throttle down: takes a few seconds to build boost, very lethargic, low power (230hp or so?). Not sure what boost it's making, I need to put a gauge on it.
Car has:
*leaking Kirban Adj. FPR on it
*MSD Ignition
*Magnecor 10mm wires
*Green-topped Bosch Fuel injectors (any idea if these are stock or not?)
*some funky mushroom hex-head grey banjo bolt in it at the boost pipe.
*Stock Air filter, exhausts, cat, muffler, nothing else visibly different.
Also, e-brake engages kinda low, & car squats quickly on acceleration, so I'll check tonight to see if the cable is allowing the e-brake drums to not fully disengage.
Thoughts my friends??http://forums.pelicanparts.com/uploa...1214235588.jpg
Darkhorse 06-23-2008 02:19 PM
When I bought mine I discovered that the inner skin of the exhaust ahead of the Cat had collapsed. It could be that if the exhaust is original. It could be a lot of other things also.....
MarkRobinson 06-23-2008 02:21 PM
Yes, I helped a guy in Austin 2 years ago via email trying to discover his issue: he found that too! I need to do the entire exhaust (cat too) to be sure it's not that: in the plans anyway. :)
Spidey944 06-23-2008 05:23 PM
They make a backpressure tester that screws into the O2 sensor bung. Anything over 1-2 pounds is too much IIRC.
nize 06-23-2008 07:56 PM
get a boost gauge asap. what does the stock gauge read?
know what chips it's running on?
have you performed a compression test yet? results?
btw, the stock bosch injectors have green connectors;
http://gallery.silentmedia.com/d/12061-4/acw.jpg
MarkRobinson 06-24-2008 05:28 AM
Pooh, I was hoping the green-top injectors were larger & that the chips were appropriate. I have yet to check the computers to see what chips are in it. I don't think it's boosting more than stock, but haven't checked it yet.
I plan to update the exhaust anyway, so not going to spend the time checking the backpressure, but a good note: didn't know that existed.
I had Porsche do a PPI on the car: clean compression & leakdown. (nice o-rings on those injectors pictured above)> :)
Mark
nize 06-24-2008 08:12 AM
hahah, that was the 'before witchhunter' shot. here are the same plugs after;
http://gallery.silentmedia.com/d/12064-5/acx.jpg
MarkRobinson 06-24-2008 10:17 AM
Pretty. Does anyone know how much fuel the factory injectors will flow? I remember back 10+ years ago, my 951S dyno'd 357rwhp/345rwtq @ 17psi on pump gas through the stock injectors.
Mark
nize 06-24-2008 10:37 AM
http://www.clarks-garage.com/shop-manual/fuel-12.htm
stock bosch injectors = 384 cc/min @ 3 bar (approximately 36lb injectors)
i would be interested in seeing that dyno from 10+ years ago with afr, as i'm sure you were either over-running the stock injectors at those settings, or losing a lot of power towards redline.
on my original 2.5 motor with siemens 55lb injectors (approximately 578cc) at 17psi, the injectors were running very close to 98% duty cycle at 2.5bar, so i know the stock injectors would not have cut it.
MarkRobinson 06-24-2008 11:17 AM
My dyno was just months before they bought the WB sniffer: so no AF's :(
Mark
