Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
DME chip
Hello,
I am in France and i have got a guru racing kit for my 951 ( year 1985 ), in my car the DME have a chip with 28 pin and the guru DME chip have 24 pin, on my DME platinum are drawing the two chip ( 24 and 28 pin ) can y install the 24 pin DME on the 28 pin support ? must i do any modification ?
Thank you very much for you answer .
Christian.
Old 06-25-2008, 12:44 AM
Are you sure it's a 951 because they didn't start making 951s until 1986
'86 951 Guards Red, MBC, Adjustable FPR, Venturi Delete, LR Exhaust
Old 06-25-2008, 05:22 AM
Yes i am sure it's a 951, it's the 951 number 14, one off the first who was built, but the DME is not original, it was probably replace by the preceding owner
Old 06-25-2008, 06:13 AM
In the Fires of Hell.....
kdjones2000's Avatar
Salut Christian!
Here's is everything you ever need to know about this: http://www.frwilk.com/944dme/88_to_86.htm
Cheers,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-25-2008, 02:14 PM
Architecture & Porsche's
Yes, europe: 1985. US, 1986
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 06-25-2008, 02:23 PM
Originally Posted by kdjones2000 View Post
Salut Christian!
Cheers,
Keith
Thank you very much
Old 06-25-2008, 03:03 PM
... if later i have à problem with a faulty guru chip ( DME or KLR ) , where can y find a new chip to buy ?
Salutation from France
Christian
Old 06-25-2008, 04:16 PM
Super Moderator
nize's Avatar
maxhp;
http://www.maxhpkit.com/
vitesse;
http://www.vitesseracing.com/
lindsey used to have a trade-in deal where he'll give you $50 credit for your old chips;
http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Co de=CHIPS
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 06-25-2008, 04:29 PM
Or if you know anybody with an eprom (chip) burner, they should be able to build a new image file from your original 28 pin and guru 24 pin. IIRC the last 4kb of the 28 pin chip is for the 4kb of information found on the 24 pin chip. I've done this for somebody else back when I had my eprom burner. Just have them compare the 2 images and you can find out exactly where the 24 pin chip data begins on the 28 pin image file.
Old 06-25-2008, 05:30 PM
