-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Explanation needed: function & testing of the Cycling valve (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/416827-explanation-needed-function-testing-cycling-valve.html)
MarkRobinson 06-27-2008 08:07 AM
Can some one break this down for me? I know the KLR is attached to this electronically, so I'm unsure as to disconnecting it as I've read before: is there a test & I did read about sealing it up.
Clarifications on this are appreciated. :)
MarkRobinson 06-27-2008 08:10 AM
Stock wastegate limits/disadvantages?
moved comment to new thread
MarkRobinson 06-27-2008 08:27 AM
951Max chips vis Vitesse vs Guru
moved to a new thread
kdjones2000 06-27-2008 09:57 AM
The cycling valve controls the turbocharger (obviously). If you are going to a electronic/manual boost controller, I understand that you can take the cycling valve out of the loop.
Nize and other know more about this.
nize 06-30-2008 02:23 PM
read this;
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/247640-bypassing-cycling-valve.html
