Turbos not kicking in
So I'm looking at purchasing an '86 944 Turbo and was out driving it for the second time this weekend. It drives alright but the turbos don't really kick in. You can hear them spooling and see the boost but never delivers the punch.
Any idea on the cause of that? Am I looking at a turbo rebuild or a new one? There's a bit of hesitation in 2nd gear so wondering if there are some vacuum leaks. Haven't bought the car yet but wanted to do some research to adjust my offer accordingly. Thanks. |
Sounds like vacuum leaks. Is the boost gauge on the dash going above 1 Bar? If not than no boost is being generated.
'87 944 Turbo |
Of course, you realize that a 944 turbo only has one turbocharger... If you're expecting more than that, you will be disappointed...
Good luck, George Beuselinck |
Banned
Banned
yeah maybe the oil gauge?
the boost gauge is under the tach. it read from .4 bar, to 2 bar. a stock 944 turbo should run a bit under 1 bar at idle, but when at WOT and above about 3500 rpm, be at 1.8 bar. most aftermarked 944 turbos will peg the stock gauge at 2 bar. |
Are you sure it's a turbo car?
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Super Moderator
can you post up a photo of the engine bay?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Ornery Bastard
Only if it has a MASSIVE vacuum leak...
A stock 944 turbo should run between about 0.33 and 0.4 bar at warm idle. The gauge should read roughly 1 bar when the engine is off and the key is in the "run" position because in that case it's reading atmospheric pressure. Sounds like you're looking at the oil pressure gauge. In which case the car has problems. At hot idle there should be at least 2 bar of oil pressure. With only 1 bar of hot oil pressure you're looking at rod bearing problems in the car's future. Or the oil pressure sender / gauge is dying. These cars should normally see between 2.0 and 4.5 bar of oil pressure, with 2 bar being at idle and 4.5 bar being at redline.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) Last edited by AaronM; 08-26-2014 at 03:46 PM.. |
Thanks for the additional posts. The seller took the car in and they said it's either a clogged fuel filter or vacuum leak which isn't too scary.
Good news is the guy is going overseas with the Air Force this week so he is selling me the car for a song! Don't want to jinx anything yet b/c I don't pick it up till tomorrow but I will post pics and updates on all this once the transaction is complete. |
Ornery Bastard
Also, if a mechanic cannot diagnose the difference between a clogged fuel filter and a vacuum leak, that mechanic isn't someone you should allow to work on your car. This is a common scam used to stop people from worrying about why a car has a suspiciously low price.
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Remember, these are old cars with lots of wear and tear. The Turbo models can be driven much faster and harder than the non-turbo versions, so you can be looking at more worn-out brakes and suspension. The engine itself is typically always more worn out than a 944 with similar mileage.
Get it inspected by your own mechanic who's familiar with 944 Turbos!!! It's definitely worth the cost as there is no such thing as an inexpensive 944 Turbo. In fact, the cheaper the price, most likely you'll have to spend way more on repairs to get it back to decent running shape. Most of the time, it'll cost you less in money and headaches to get one that costs more and requires no major surgeries. There's an endless list of people who've bought a "cheap" $5000 944 Turbo that had to spend an additional $5000-10000 to get it running. |
Porsche 944S Club Sport
Check for exhaust leak.
Check when car starts up cold. Use the tissue paper test. if you can"t feel heat or hear it. Check exhaust o-rings between Header and cross over pipe and at wastegate "Y" below. Later....
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
I bought the car well under $5k and I'm sure there's plenty that needs to go into it but I've got service records back to the 90s. A replacement dash/door panels, a brand new timing belt/02 sensor/cat back exhaust and the car runs good just not quite perfect. Does anyone have any experience with those silicone vacuum hoses they sell on ebay? There's generally two kits, one for $35 and one for $125 with about 3x the length plus a hose cutter and instructions. Figured if I'm in there searching for possible vacuum leaks then might as well replace the hoses. |
Ornery Bastard
And with that new timing belt, did he also change the rollers and water pump? If not, how old is the water pump? It should be changed every other timing belt. Still, I'm pulling for you and hoping you got a good one. Looking forward to photos once you have it.
Water pump was changed last year if I'm not mistaken but I have a receipt for it. Before I start cutting off vacuum hoses I'm going to swap the fuel filter and check the records to see when the last tuneup was. Maybe pull the plugs to see how they're looking. |
