Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Still losing boost !!
Hi all I fixed the fuel issue compression test was as follows
#1 135psi
#2 135psi
#3 128psi
#4 140psi
I am still losing boost I think some where at part throttle the car pulls good at WOT it wont go anywhere and I here the hiss sputter under the car it fells like I am losing the boost!! Thoughts??
Old 09-08-2008, 04:51 PM
Super Moderator
nize's Avatar
have you checked the BOV to make sure it's not leaking?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 09-08-2008, 07:39 PM
Where would it leak to does it blow off to under the car or back to the intake. How would I test it ?? Pete
Old 09-08-2008, 07:49 PM
Super Moderator
nize's Avatar
check this thread;
Blow off valve question, Please help!
and this one;
Just bought 951 a few questions
and possibly this one;
Acceleration Drop Off Question
use the forum search feature and search for: blow off
Old 09-08-2008, 07:56 PM
jmj996's Avatar
The one that got me this past weekend was the vacuum connection UNDERNEATH a metal section of the air intake leading directly to the intake manifold - just left of the BOV/diverter valve (if you're under the hood facing the engine). Once I got that connected, MAJOR improvement.
Prior to this problem, I was getting pretty solid boost, and then in the middle of a run, under acceleration, I lost most of my boost, it was like it was capped off. I found two vacuum connections that came undone - the one I described above, and the one between the fuel damper and the connection at the intake manifold.
If you really want to eliminate these vacuum gremlins, get a complete vacuum replacement kit with the hoses and connectors and replace everything. I had the Lindsey vacuum hose/connector kit from Paragon with me at the track, and that saved my butt big time. Next step if that doesn't resolve it is to replace the items connected to the vacuum lines - BOV/diverter, fuel damper, fuel pressure regulator, etc. in case any of them have a torn diaphragm (or if you can separately diagnose those parts to confirm they're holding vacuum, even better). If you buy stock diverter/damper/FPR and the vacuum hose kit, you'll spend about $200-$250 total, and you'll have eliminated another source of future problems. My 1986 has 137k and between the previous owner and I, all of this has been replaced.
Good luck!!
99 996 cab: 2004 - present,GT3 & Strosek mixed body
86 951: 2008 - present,951MaxChips,LSD,LBE,924t hood & rear spoiler, Koni/Eibach/Ground Control, 3Bar FPR, lowered,brake cooling, Lindsey spherical bushings
99 986: 2002-2006, PSE (my favorite of the three, but with kids, it had to go)
1986 951 pic
Old 09-09-2008, 09:47 AM
Super Moderator
nize's Avatar
all you need is a mity-vac hand pump to diagnose vac leaks in the system. another good investment for around $30;
Old 09-09-2008, 10:01 AM
jmj996's Avatar
Very nice, I'll have to borrow one of those some day, that would ensure I've completely knocked out my vacuum gremlins.
1986 951 pic
Old 09-10-2008, 09:50 AM
