Bleeding ABS
Anyone know if or how you bleed the ABS unit on a 944 Turbo. I just replaced my master cylider and blead everything and just want to be sure I didnt need to bleed anything with the ABS.
Also after replacing the master cylinder my ABS light is now on and Im unable to determne how. I have a ABS reset switch but that isnt doing the trick. Thoughts Thanks Brian
1989 944 Turbo Cup Replica PCA Space Coast Region #44 |
Super Moderator
did you use a stopwatch to time the abs reset procedure? you have to be dead-on with the timing or the reset will not work.
abs bleed procedure is no different than non-abs bleed procedure.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
No I did not use a stopwatch. I just hold the button down and after a second or so the light shuts off on the dash.
Super Moderator
arg, i thought you were talking about the air bag. have you tried this?
http://clarks-garage.com/shop-manual/elect-12.htm
