Boost/Acceleration Problems
Hi Everyone:
I am having problems with my acceleration. I think it is vacuum related but I can't find anything wrong. When I accelerate sometimes the car: (1.) pulls strong and the turbo boosts to 1.8 bar, (2.) only boosts to 1.2 bar, (3.) boosts to 1.6 bar but the engine stutters, (4.) hesitates and stutters all the way through the rpm range. It does seem to do it more when the engine is warm. I have inspected the vacuum lines as much as possible, put a gage on some of the lines (they all read good at idle), and tested the cycling valve. All seem good so I am having a hard time figuring out what is going on because the performance is so inconsistent. Any suggestions would be appreciated. ThanksSmileWavy |
Check the connectors to the hardpipes by the intercooler. You will have to pull them off to really see but they tend to deteriorate underneath and depending on how cold it is the turbo can still make pressure but when warm it is more noticable.
The connection at the turbo to the hardpipe can also split You may also want to check the ISV |
You'll need to provide more detail to work with. You will need to continue the troubleshooting/diagnostic path you already began, i.e. confirm that all vacuum-connected devices (FPR,Damper,BOV,etc.) will hold vacuum in order to ensure there are no torn diaphragms. Do you hear any hissing only under boost? Are you sure your FPR and Damper are good? When those are bad, they can display a wide range of symptoms. The significant stuttering you described makes me think the problem is possibly more significant than a vacuum leak. The TPS switch is also suspect. If you can sometimes boost and run just fine when warmed up, and stumble at other times, I don't think the problem is vacuum, possibly electrical.
From Clarks Garage Fuel Pressure Regulator Failure Symptoms: Engine runs rough Engine stumbles or sputters Engine runs very rich - black smoke from the exhaust Engine will not start Engine starts but stalls shortly after startup Noisy fuel pump Noticeable decrease in fuel mileage The following lists some of the symptoms that MAY indicate a problem with the throttle position switch: Poor idle - particularly a high idle condition Engine cuts out to an idle condition during acceleration Poor power at various RPMs (various throttle positions) Surging idle Misfire Stumble during acceleration Intermittent boost problems (turbocharged cars) |
bad gas?
water in the gas tank? have you checked the blink codes yet? what does it show? do you have a knock counter? it would make diagnosing knock quick and easy. counter info can be found here; http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/433157-knock-counter.html#post4210398 |
I believe the BOV is good, I tried to clean the TPS with carb cleaner (no change), and I have no idea about the FPR or the damper. How do you check those items?
Thanks |
I am sure the gas is good Nize. How do you do the blink codes? Also, what is a knock counter? Thanks
updated my post. re-read please. :)
you might also want to check clark's garage for the info on blink codes.
Thanks Guys
Nize-I got info for the blink codes from another thread. Do you make the LED or is that something that you can buy?
Thanks |
you make the LED using parts from radio shack. :) it's very simple. details on lindsey;
http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Co de=BLINKCODE |
Thanks, I will try it tonight. I'll let you know what happens.
ok Nize, I I'm getting a blink code of 3-3 so either the KLR is bad or the TPS. Do you know how to test the TPS? Thanks. PS. that blink code test is awesome. I had no idea you could do that!
here's info on how to test the tps;
http://clarks-garage.com/shop-manual/fuel-06.htm be warned, i had an intermittent problem and the tps tested okay. i later found out that when the tps gets hot it tests faulty. so i think the only real way to 'test' the tps is to replace it with a known good one and see if the problem goes away. |
Thanks Nize.:)
OK, I tried to clean the TPS and reinstalled it. Now the only code that I have been getting today is 2-2 whch is Knock sensor monitoring- Knock sensor supplies excessivly small or no signal or K/CP control unit is deffective. 1. The K/CP control Unit is the DME right? 2. I put an ohm metter on the #11 and 13 terminals of the DME. I don't know much about electricity but on no setting on the meter (2K, 20K, or 200K) did I get 270 to 330 kohm like the service manual says so does that mean that the DME is bad or could there just be a grounding problem? 3. Also does the kick plate have to be fastened to the body to be grounded? The PO did not screw the kick plate down. Again, as you can tell I know nothing about electrical issues. Thanks:confused:
i had a similar problem with the knock sensor. turned out that the wiring had been partially cut. i had to take the intake manifold off to clean it. could also be that you have a bed knock sensor. it is possible to replace it without removing the intake manifold, but in the end it may take less time to just pull the manifold.
the metal dme/klr frame does have to be fastened to the body to be grounded.
| All times are GMT -8. The time now is 02:04 AM. |
