Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 944 Turbo and Turbo S
WBWSAIL's Avatar
Brake fluid reservoir seal?
After running in my first DE event, I found the top of the master cylinder reservoir covered in brake fluid after each run. The fluid level is right between the min / max lines, so it's not overfilled. When I did a brake fluid flush prior to the DE, I was surprised to see there is no o ring or gasket sealing the fill cap to the reservoir on my car, a 1988 951. I don't see an o-ring or gasket listed on Pelican or the other parts sites, so I assumed there just isn't supposed to be an o-ring there. Or did a previous owner maybe loose it? Should there be one there?
Thanks for any help
Old 09-30-2008, 01:27 PM
jmj996's Avatar
I experienced the same problem on my first two track days with a 951 earlier this month, and even had brake fluid spilling over and way down, causing it to burn and smoke. I'd love to know the answer to this.
99 996 cab: 2004 - present,GT3 & Strosek mixed body
86 951: 2008 - present,951MaxChips,LSD,LBE,924t hood & rear spoiler, Koni/Eibach/Ground Control, 3Bar FPR, lowered,brake cooling, Lindsey spherical bushings
99 986: 2002-2006, PSE (my favorite of the three, but with kids, it had to go)
1986 951 pic
Old 09-30-2008, 06:29 PM
Super Moderator
nize's Avatar
could it be due to the sealing surface on the cap itself? it might be time to replace the cap. part number 951 355 351 00 available here;
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait= N&make=POR&model=944M&section=BRKhyd&page=1&bookma rk=2&part_number=951-355-351-00-M100
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 10-02-2008, 03:35 PM
A Mercedes cap also fits but you will lose the low fluid warning aspect of the cap. I used to substitute the cap from my 1980 450SL when I took the 944 to the track. It does not leak and is one piece except for the gasket.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 10-03-2008, 09:50 AM
I ran my first track event with a brand new resevoir and cap two weeks ago. It was moist at the end of each run. I have that cap and the power steering resevoir on my list of things to wipe with a rag at the end of each day.
Old 10-23-2008, 07:31 PM
https://www.pelicanparts.com/More_Info/34-32-1-102-798-M33.htm
I think I found the exact aftermarket part needed for $2.00 (FTE 34-32-1-102-798-M33).
The ATE cap / float stem / rubber gasket looks to be identical for some VW Rabbit, BMW E30, and Mercedes E300 assemblies, however, the ATE reservoirs looks different for these cars.
Old 02-15-2018, 04:15 PM
In the Fires of Hell.....
kdjones2000's Avatar
Well you almost made it to a 10 year time difference between the last post on this thread and your reply.....
Maybe next time
'88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG
3300 lbs, 256 RWHP, 15 psig boost
"Certified National PCA Instructor" Hoooohah!
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
Old 02-16-2018, 02:57 AM
Newbies, keeping threads alive since 2008!
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 02-16-2018, 03:13 AM
Super Moderator
nize's Avatar
this is why the 951 cult withstands the test of time...
Old 02-16-2018, 05:30 PM
