Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
vacuum tubing + Boost gauge question
I've got my boost gauge hooked up right now using a compression fitting T on the vacuum line heading to the ECU - this is with stock vacuum tubing.
The compression fitting T on two sides is the regular stock tube, and on one side converts down to 1/8" (which is the size tubing that came in my VDO gauge kit).
Anyhow long story short I need to replace the vacuum tube going from the intake manifold to the T right before my ECU - but all of the tubing kits I find use a thick outer diameter tubing that will not work in my compression fittings.
I want to replace all of the lines with the type of tubing that Lindsey sells, but I can't figure out how I can get the right fittings to connect to my VDO gauge.
I suppose I'd need a T, as well as a barb type screw on adapter to attach the vacuum line to the back of the gauge.
Problem here is, I don't know a) where to go to get this stuff b) What any of it is called. NAPA looks at me like I'm retarded...
Any help?
Old 11-01-2008, 08:38 PM
In the Fires of Hell.....
kdjones2000's Avatar
Try a local speed shop. They should have what you need.
I tried NAPA, and they didn't have squat. I actually got my gauge lines from Lotek (http://www.gaugepods.com/porsche.html), as they seemed to have the best price, and it had the T-fitting included.
Good luck,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 11-01-2008, 09:00 PM
Awesome, that line kit from lotek looks perfect, I see the plastic T that I will need!
Order placed!
Old 11-01-2008, 09:09 PM
