Transmission Oil recommendation
I need to change my trany oil in my 1988 944 Turbo S with 88k. Any recommendations on what oil to use for the trany?
Thanks |
Is it a 5 speed? if so, when I researched this I came up with Redline MT-90. That's what I use and it works fine, but since I have never used anything else I can't tell you from experience how it compares to other brands.
In the Fires of Hell.....
Well, you have an LSD so you need to make sure to use oil that works with yours properly.
A lot of people recommend Swepco and Redline fluids for ours. I put Royal Purple into my non-LSD 951 tranny and have been happy with the smoother shifting and lower noise. Cheers, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Anyone use Amsoil?
I have an 86 with an LSD and cooler and need to change mine before my next track day in a few weeks. Has anyone used Amsoil? I looked at some testing results for wear and protection and Amsoil appears to beat both Royal Purple and Redline by a significant amount.
99 996 cab: 2004 - present,GT3 & Strosek mixed body 86 951: 2008 - present,951MaxChips,LSD,LBE,924t hood & rear spoiler, Koni/Eibach/Ground Control, 3Bar FPR, lowered,brake cooling, Lindsey spherical bushings 99 986: 2002-2006, PSE (my favorite of the three, but with kids, it had to go) 1986 951 pic |
In over my head
I am using Amsoil in my 86 with an LSD. No issues to date (5,000 miles) and no chattering from the LSD. I believe that is rated for LSD use.
http://www.worldsbestoil.ca/GL4-Synthetic-Manual-Transmission-Lube.php
Fergus 86 951 Graphite Metallic 86 944 n/a Garnett Red Metallic (SOLD!) 74.5 Triumph TR6 (restoration project) 05 Subaru Legacy (winter car) |
Super Moderator
why does everyone keep asking this question?
swepco 201 (blue) is the only transmission oil that should be used for these cars; http://www.swepcousa.com/lubesite/gear.htm it's available from right here on pelican; http://tinyurl.com/ytsb6u
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
