Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Timing belt tools
Hi, i am doing the timing belt on my 86 951. I was seeing if there are any good alternatives to buying the tensioner tool from pelican or performance parts? Has anyone had good success with the cheaper alternatives? If i have to buy the genuine porsche tool i will but i am trying to avoid it. Thanks.
Old 12-02-2008, 08:52 AM
In the Fires of Hell.....
kdjones2000's Avatar
Get the Arnworx tool. It does as good a job, and costs a lot less.
If you are really low on funds, the Krikit tool is the least expensive, but also least accurate method.
There is also the "Twist" method, but that one requires some experience to do properly.
Do a search on the forum and you will find all of these things described.
Good luck,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 12-02-2008, 11:05 AM
Thanks. I appreciate the info.
Old 12-02-2008, 11:58 AM
Send a message via Yahoo to chris.817
I just used the Arnnworx tool for my first belt job. Works great!
Chris
87 Carrera Coupe - Guards Red on black
00 Carrera Cab - White on Navy
05 Carrera S - Atlas Grey on gray
86 951 - India Red on black - Sold
Old 12-03-2008, 06:47 PM
What kit did you order?
Old 12-05-2008, 07:15 AM
I just ordered the 920X tool only. A regular 24mm open end wrench works on the eccentric, and I didn't need the flywheel lock at this time.
Chris
Old 12-05-2008, 09:34 AM
