Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Need Help w/ Radio
I'm looking to replace my Blaupunkt with a Pioneer DEH-P700BT. I'm looking for a harness adapter to go in between the Pioneer and the factory OEM harness. Or the mating connector for the factory harness so I can fab my own adapter.
86 951 blk
Old 01-11-2009, 06:02 AM
bearone2's Avatar
crutchfield has the adapter separately and it comes in the kit if you buy the radio from them.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 01-11-2009, 08:40 AM
Thanks!
86 951 blk
Old 01-11-2009, 06:51 PM
Can anyone id these connectors? I noticed them while prepping to install a new radio head unit. Three of them (inclusive of a non-highlighted brown/ground) are part of the same wire harness while the lone lower one is on its own. Thanks
86 951 blk
Old 01-24-2009, 05:35 AM
This is from http://www.the12volt.com/installbay/stereodetail/1914.html Unfortunately it does not seem to describe the wires you have in the picture...
1986-88 Porsche 944 Stereo Wiring
Constant 12V+ Yellow
Switched 12V+ Red
Ground Brown
Illumination n/a
Dimmer Blue
Antenna Trigger White
Antenna Left Rear
Front Speakers 4" x 6" Doors
Left Front (+) White
Left Front (-) Black
Right Front (+) White
Right Front (-) Black
Rear Speakers 4" x 6" Side Panels
Left Rear (+) White
Left Rear (-) Black
Right Rear (+) White
Right Rear (-) Black
Old 01-25-2009, 04:24 PM
TexasBlake's Avatar
I used the Crutchfield adapter, but one of the wires was incorrect and had to switch terminals.
Old 01-26-2009, 07:04 AM
aribop's Avatar
You should have another harness under there that is terminated with a connector like the one pictured above. If someone cut that connector off, you should still have another harness end with the correct wires.
The wires in your picture are for the equalizer/booster connections. That one lone wire looks as if it is for the antenna signal amplifier.
'95 993 Monster in the making
'89 S2/Turbo aluminum grill monster: terrorizing another state
Old 01-27-2009, 04:12 PM
Thanks - so the antenna signal booster be connected for better station reception?
86 951 blk
Old 01-31-2009, 05:14 AM
