Cam assembly torque specs
Reassembling my cam tower and couldn't find the torque specs in Hanyes or Clarks. Does anyone have these specs?
1) front cam cover 2) rear cam cover 3) cheese hd bolt Really appreciate your help/ Thanks |
Custom User Title
Yeah, it's there: http://www.clarks-garage.com/shop-manual/cam-02.htm
The bolts are 14 FtLbs for the cam tower. There isn't a seperate spec for the rear cover (the one with the cork gasket). I haven't got a clue what cheesehead bolt you're talking about. I just looked. The factory shop manual calls for for the following torque tolerances:
I hope that helps. I had a real pain with mine (I stripped a couple of the hex head bolts taking it off). When I put it back together, I used all new bolts so that next time, it should be easier.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Don't know how I missed it! Thanks
It's odd, seems reversed in the torque specs for the housing and the plugs. You'd think the bolt's holding the housing would be 29# and the plugs 15#...go figure? |
