Headlight Problem on 1986 944
Hello.
I recently purchased a 1986 944 Turbo and the previous owner took out the headlights and replaced them with a filler panel. Well, I wanted to return it to factory condition and when I replaced all the original headlight parts I am experiencing a strange problem. The headlights open but they do not come on. You can put them on either high or low and no lights. You can however pull the turn signal back to the "flash" position and they will turn on. Let it go back to normal or high and they turn back off. I have checked all fuses and they are good and I cannot find any relays for the headlights. Any suggestions? |
I got them working but dunno how. All I did was take off the steering wheel and put it back on. Who knows?!?!?!?!?
Super Moderator
probably a bad ground or loose wire somewhere?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
