| Registered Join Date: Jul 2003 Location: gosford australia
				runs fine until boost starts
			Hi my 89'951 runs fine until the boost guage hits the 1 bar mark , then it is like it has swallowed a sock, I have checked the vacume lines and they appear ok. any tips. thanks Russell
				__________________ 89,951 sunday car/ 05 ,525i family car/ X5d every other day/ wellcraft eclipse21- 350 chev | ||
|  03-28-2009, 07:36 PM |
| Super Moderator |
			you probably have a big leak somewhere in the intake plumbing.
				__________________ '89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) | ||
|  03-28-2009, 09:45 PM |
| Registered Join Date: Apr 2009
			You should check the full car from a mechanic. I believe that he will solve your problem.
|  04-07-2009, 12:58 AM |
| In the Fires of Hell..... |
			We really need more detail than that to help you out, if that's what you are asking for...
				__________________ PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost | ||
|  04-07-2009, 12:25 PM |
| Super Moderator |
			maybe there is a sock somewhere?
|  04-07-2009, 12:36 PM |
			I know what happened!  The sock used to run the Alternator, A/C and PS must have fallen off and landed in the turbocharger      That would explain things....
|  04-07-2009, 03:18 PM |
			Problem found, loose connection between turbo & intercooler. thanks
|  04-11-2009, 03:56 PM |
| Super Moderator |
			good to hear!
|  04-11-2009, 09:42 PM |
