Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Pic's of 944 turbo S clutch disk please?
I understand the 944 TurboS's clutch disk has a different springed center section to put less stress on the transmission with its higher TQ levels.
Dose anyone know about this?
Any Pictures?
Anyone know if that disk can be adapted to a Carrera 911?
Thanks.
Old 06-04-2009, 04:25 PM
I have it listed as the same clutch for 86-89 951's, definitally a different center then a regular 944 though
Old 06-16-2009, 11:49 AM
I think different diamtier disk also.
Old 06-16-2009, 12:47 PM
Super Moderator
nize's Avatar
there's another extensive thread on here that already discusses clutches, you should be able to find photos in that thread.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 06-18-2009, 12:24 PM
I will just look up clutch in title.
Thx
Old 06-18-2009, 12:28 PM
In the Fires of Hell.....
kdjones2000's Avatar
clutch for 951
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-20-2009, 07:33 AM
Thanks all, that is what I needed. The 944T S disk has a two stage spring setup to reduce shock on the transmission. It helped being able to see it against the stock style clutchs.
Old 06-20-2009, 07:56 AM
