Water Pump for Turbo Not Working
It appears that the water pump for cooling the Turbo is no longer funcitoning. The fuse if good. Is it possible that the relay in the fusebox is bad? How do you check this?
Thanks for your assistance. |
are you sure the water pump is good?
Not sure, trying to eliminate the simple stuff first. Just got a detail process to check. Will need to work through the steps to confirm which part is broken.
if it comes down to the relay being bad i have a new one in the box....ill help you to save some of the $175 they are new. but i would put power to the pump and make sure its working, not uncommon that they sieze up
Thanks for the offer. It appears at this point the pump is bad. I applied the direct power and nothing happened.
http://www.texasblake.com/porsche/tech/turbopump.html |
If you check the Rennlist forums, I found a writeup for repairing this pump yourself. I could not get a link, otherwise I would have posted one.
Anyway , in the 944 forum over there do a search for "Repairing my turbo water pump" and you will find it. In that case a simple resolder was all that was needed. It's a nice writeup with pics. Good luck. Kevin |
