Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Architecture & Porsche's
How to smartly remove 951 Radiator fans
From Underneath the car, it appears it comes out the top, but from top, it appears to come out the bottom: thoughts anyone??
Mark
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-14-2009, 05:45 AM
In the Fires of Hell.....
kdjones2000's Avatar
I just did this recently, but the details are already a bit foggy.
I think that I loosened up the fans and radiator, removed the radiator from the bottom first, and then the fans come out easily. This is the messy way, of course
I see no way to remove the fans from the top if you have not removed the coolant manifold, so my vote is from the bottom.
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 07-14-2009, 12:37 PM
winter-hater club member
nynor's Avatar
i am pretty sure i pulled mine from the bottom, on my turbo. i KNOW i pulled them from the bottom, on my '83....
"COOL PRIUS!" - Nobody Ever
Old 07-15-2009, 06:50 PM
bearone2's Avatar
bottom
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 07-16-2009, 06:27 AM
Crap, they will not come out without removing the hard oil cooler line, & possibly the cooler, and probablyl draining/removing the lower radiator hose: weee. Not enough space to wiggle it out, it wont rotate & it's too thick.
Mark
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-17-2009, 12:32 PM
Super Moderator
nize's Avatar
the last time i did this, i think i got it out via the top after removing the intake box, etc.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 07-17-2009, 12:36 PM
I will look tonight, but it looks like the steel coolant "manifold" is in the way: thoughts on that?
Mark.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-17-2009, 12:39 PM
Super Moderator
nize's Avatar
while i don't clearly remember if i removed it from the top or the bottom, i do clearly remember that the fan will not come out in the orientation it's in. you have to rotate it 30-degrees or so, and keep playing with the rotation/position while getting it out.
Old 07-17-2009, 02:47 PM
Mark
That's why I drop the radiator first, then they come out easily...
Old 07-17-2009, 03:49 PM
I managed to get my fans/shroud out and a new set in the bottom without removing anything except the fan switch connection at the top drivers side of the rad. But, I was really, really pissed off that day, so that probably helped...
I tilted it down on the drivers side, some serious
Old 07-23-2009, 11:29 AM
Sorry guys, not sure what just happened to get that posted 4 times...
Anyway, what I MEANT to say was, I tilted it down on the drivers side, some serious wriggling to get the top left corner past the upper rad hose, then out it came. As Haynes would say, install is the reverse of removal.
Old 07-23-2009, 11:32 AM
I figured it out.
1. remove both electrical connections from the fans (one on each)
2. from below and above, remove all 6 10mm securing screws so that the fan shroud is loose.
3. drain radiator & remove lower hose.
Steel oil cooler line is now in the way:
4. Remove 10mm screw on/near PS pump where oil cooler line attaches
5. remove both 10mm nuts by oil cooler to allow some movement of the hard line
6. from under car looking at fan, rotate fan about 15 degrees clockwise & work out fan, pulling against hard oil line as needed to remove fans.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 07-23-2009, 11:33 AM
bearone2's Avatar
you can edit/go advanced and delete duplicate posts.
Old 07-23-2009, 03:46 PM
