Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Which BOV to purchase?
My BOV (diverter valve) is 19 years old, so I figure it's time to be replaced with something new.
What is the best valve to get, and where? If it matters, my engine/turbo/wastegate, etc. are all stock.
Thanks!
-- Jim
1983 944
Old 04-12-2007, 06:13 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
I don't think there's any reason to replace the stock unit unless it's failing.
I bought a reworked Bosch BOV off eBay. It has all the stock dimensions, but is built out of aluminum instead of plastic.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 04-12-2007, 07:25 AM
How do I know if it's failing? I seem to recall something about sucking through the nipple on the top (settle down boys : ), and that you shouldn't be able to pull any air through? Is that correct? It just doesn't seem like a very scientific method of determining whether or not it is good.
I guess I just figured after 19 years it would be ready for replacement. Maybe that's not the case, as long as I can effectively test it.
-- Jim
1983 944
Old 04-12-2007, 08:20 AM
winter-hater club member
nynor's Avatar
^that's how you test it. i'd probably replace it with something billet.
"COOL PRIUS!" - Nobody Ever
Old 04-12-2007, 09:11 AM
soxnail's Avatar
Yup no air flow through it under normal (standard atmospheric) conditions. If you want to test it fully then:
1). Pull it off the car.
2). attach an air source to the side that goes to the hard pipe from the intercooler. (be able to provide 10 psi)
3). No air should go through the valve. If it does then the valve is barfed.
4). if it passes 3 above, then with pressure on the inlet as in step 3 apply vacuum to the nipple only a couple of inches is enough. The valve should allow the pressure on its inlet to be dumped to the outlet (the side that goes to the "J" pipe AKA THE "Alien"). If it does not then the valve is barfed.
Good luck Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 04-12-2007, 10:57 AM
Is there a reason to get a billet valve (other than my fixation with shiny parts? )
-- Jim
1983 944
Old 04-12-2007, 01:18 PM
nynor's Avatar
i *think* they are rebuildable and shiny and more durable
Old 04-12-2007, 01:28 PM
the stock piece bleeds boost and helps cause lag.
the billet ones pretty much stop this effect. something about using metal vs rubber.
also, the stock ones are only good for about 5 years.
I just picked up a 97 951 with 110k miles for 3k. the owner thought it was screwed up. but 400$ later, including tires, its running like a champ.
the bov is a big problem. id upgrade this and the waste gate. on any stock 951.
87 951 = home made MBC, Large Turbo, Autothority MAF, Mafterburner, custom fuel system w. 55lb injectors, 951MAX chips, water/mentanol injection, 2-stage Nitrous injection, punched out cat, Magnaflow muffler.
944's are like kids, the average owner has 2.5.
Old 05-09-2007, 11:00 PM
Porschefile's Avatar
What Mfloren said. Seriously though, the stock plastic DV's wear out pretty easily. Not to mention, at elevated boost levels like 14-18psi, they can wear out pretty darn quickly to the point where they don't stay shut 100% and will cause more lag. The stock type metal DV's are okay but there is better stuff out there. Forge DV/BOV's are pretty decent too.
Old 05-14-2007, 08:00 PM
Just bought a billet one, thanks for all the info guys.
I stuck a short length of vac line on the stock DV and sucked. I got lungs full of fuel-tainted air...so I think I was sucking air through the DV (kinda hard to tell though.)
-- Jim
1983 944
Old 05-14-2007, 08:43 PM
I purchased a billet one off of e-bay, 50$, and it works like a champ. no name brand but hey. its only air. right?
Old 05-14-2007, 09:32 PM
Yeah, that's what I paid. I wonder if it's the same one? I'm glad to hear it works well, thanks!
-- Jim
1983 944
Old 05-15-2007, 06:08 AM
Super Moderator
nize's Avatar
evolution motorsports billet bov. rebuildable with lifetime warranty. $50 from imagine auto;
http://www.imagineauto.com/
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 05-15-2007, 09:09 AM
Super Moderator
nize's Avatar
update: imagineauto has sadly gone out of business.
i've found this same bov elsewhere but the price has gone up to $130;
http://www.aptuning.com/products.php?productid=423
also available directly from evolution motorsports for $130;
http://tinyurl.com/kljqt6
evolution motorsports is here;
http://www.evoms.com
Old 07-21-2009, 10:56 AM
Super Moderator
nize's Avatar
here is a forge BOV for $125 in silver, part FMDV007PA;
http://www.velocityfactor.net/wwwroot/Scripts/prodView.asp?idproduct=676
$135 for a black one;
http://www.mjm********.com/catalog/product_info.php?products_id=1294
Old 07-21-2009, 12:02 PM
I have a samco recirc much like the forge ones. Totally sold on it. Great unit.
Old 07-21-2009, 12:34 PM
Architect / Car Guy
carlege's Avatar
Send a message via AIM to carlege
will the company honor the warrenty with the place that sold it out of business?
Looking Forward to getting my First "car" Porsche 951
Old 07-21-2009, 12:55 PM
Architect / Car Guy
carlege's Avatar
http://www.summitracing.com/parts/SAM-DVA2P001BLK/
is this the samco you mentioned? ($102) Looks like a good one
Old 07-21-2009, 01:00 PM
<a href="http://www.summitracing.com/parts/SAM-DVA2P001BLK/" target="_blank">http://www.summitracing.com/parts/SAM-DVA2P001BLK/</a><br>
<br>
Nope. That's atmospheric. This is mine.http://www.optionsauto.com/prodinfo.asp?number=SAM-DVR-1P-001-SL
Old 07-21-2009, 03:02 PM
your average wrencher...
can you still use the one from summit? it just dumps to the atmosphere right?
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 07-21-2009, 05:30 PM
