Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
bin files
does any one have some stock bin file they could send me, would be greatly appreciated
Old 09-22-2009, 06:35 AM
I think I do at home. I'll check tonight. Do you need a 28 pin or 24 pin bin for the DME?
Rob
Old 09-22-2009, 08:38 AM
28 pin. Thank you
Old 09-22-2009, 10:47 AM
I got them. PM me an email address where you want them sent. Also, what are you planning to do with them?
Old 09-22-2009, 04:30 PM
pmd
Old 09-22-2009, 04:40 PM
check out this thread: DIY Chip Tuning
Rogue has gone a step further than my .xdf file by calculating the fuel table values into AFR values.
Old 09-23-2009, 04:04 AM
yeah im in on that one. i hav4 the tuner rt id be sweet if he put out the software that hes modified.
Old 09-23-2009, 06:00 AM
He will be more than willing to share I'm sure.
The feature I like the most using his setup, is the MAP based timing. It is an external modification and uses a 3 bar GM MAP, but it was easy and works great.
Rogue has been helping me for over a year now, and I greatly appreciate it.
Sid
splitting my obsessions with a crow bar.
87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127
Old 09-23-2009, 07:23 AM
are you running a map sensor?
Old 09-23-2009, 07:28 AM
