splitsec arc controller question
will a splitsecond arc a/f controller work with the lindsey MAF kit? split second says the controller works for 0-5v range but i believe the LR maf is 12v? any help would be much appreciated!!!
guess nobody knows?
Yes the Split-Second controller will work. Any AFC (air fuel controller) that uses 0-5volts will work.
The LR MAF is 0-5V. -Rogue |
ok thank you very much
No problem :)
-Rogue |
| All times are GMT -8. The time now is 11:40 PM. |
