Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Porsche Enthusiast
porsche na-t's Avatar
Porsche 951 rebuild...tons of pictures
some pictures from my rebuild. last year i traded a 95 vw jetta auto to a guy that had a 1987 Porsche 944 turbo with 129k and some minor mods. car wouldnt stay running for him and he gave up. so i got it and it turned out to be a bad autothority MAF that was installed. installed stock setup and started right up. after that i started tearing it down to rebuild.
Pictures.....
1987 Porsche 944 Turbo
2005 Subaru Outback
2005 Volvo S60 Turbo AWD
Old 03-27-2010, 10:51 AM
Porsche Enthusiast
2005 Subaru Outback
Architect / Car Guy
carlege's Avatar
Send a message via AIM to carlege
Nice catch can. Ebay special. those are very affordable. Did you have any trouble with the hose size and how did you route it?
Looking Forward to getting my First "car" Porsche 951
Old 03-27-2010, 11:03 AM
Porsche Enthusiast
yeah cheap ebay special. i blew to much $$$$ on everything else. i didnt have much blow by anyways but i just have a silicone 90 degree elbow from the top of the AOS into some silicone hose to the can then to the MAF pipe. nothing special. just thought it might interupt the air enough to catch some oil.
2005 Subaru Outback
Old 03-27-2010, 01:05 PM
Will you dyno it?
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 03-28-2010, 08:58 AM
Porsche Enthusiast
yea im going to need some dyno time to help tune. so hopefully i can put down some decent numbers.
2005 Subaru Outback
Old 03-28-2010, 02:24 PM
your average wrencher...
looks good man, nice build so far... who makes the IC?
me thinks you made out pretty well with the jetta trade......that's sort of how I got my 951 except I traded a 944S for it.
1986 951 Garrett turbo, Rogue Tuned.
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
1988 XJ 5in lift,long arms, 4.6 stroker, ax-15 w/ 35s
1995.5 Audi S6 Full RS2 bolt-ons, EFI tuned.
Old 03-28-2010, 06:37 PM
Nice! Im growing quite sad as Im in the process of selling my track prepped 951 to buy a 928 S4 to install my turbo kit in.
1988 944 Turbo: Modified Corvette Killer
Old 03-28-2010, 11:12 PM
Porsche Enthusiast
running cold- my buddy and i made it. just bought a core cant remember who makes it. i did the blueprinting and he did the aluminum welding. yeah i gound it on craigslist in philly adn went down that night and traded.
Piperporsche- yeah next its gettin track prepped with cage and all equipment. wow 928s4 with a turbo kit. should haul some ass!
2005 Subaru Outback
Old 03-29-2010, 08:42 AM
I sure hope so. Id like to find another 951 to build from the ground up. Keep us updated on your progress! Have fun!
Old 03-29-2010, 09:32 AM
Porsche Enthusiast
nissan quest alternator
just installed the nissan quest alternator.
2005 Subaru Outback
Old 04-08-2010, 07:43 AM
will944's Avatar
Send a message via AIM to will944
Nice looking build!
BTW - is that your Jeep? If so....what size Rims/ Tires? 10" rims, 8" rims?? I'm lifting my XJ and am having a difficult time deciding what rim size to go with.
10 E92 M3
13 Jeep GC Limited
98 Jeep Cherokee
87 951
C3 Stingray
Old 04-08-2010, 01:17 PM
Porsche Enthusiast
thanks! no not my jeep my neighbors jeep. i can look at the size and stuff for ya. ill PM you the info when i get it.
*if anybody is interested im probably going to be doing a couple of the alternator mods if anybody is interested. the only thing you will have to do is get the right belt (not sure if stock one will work or not) and swap on your pulley. PM me
2005 Subaru Outback
Old 04-08-2010, 03:57 PM
what all did you have to do to the bracket on the alternator? and did you enlarge the key-way for the stock 944 pulley?
will944 - what lift are you considering for your xj? just to keep it legal, i'm running tj fender flares with 15x8 steel cragar v-5s with 35x10.50x15 ltb swampers. only about a 4.5-5 inch lift
Old 04-08-2010, 05:50 PM
Porsche Enthusiast
first off you have to remove some aluminum behind the pulley(first pic), then take alittle off each side to open it up to fit and drill out the hole to fit the 944 stock bolts and tapped ther other side(2nd & 3rd pic), there is no keyway on the nissan alternator i cut it in there and used the stock key. i got mine from the junk yard and dismantled it cleaned everything and checked brushes becuz they are internal now. i also got the stock plug with it for a clean look.
2005 Subaru Outback
Old 04-08-2010, 09:57 PM
Porsche Enthusiast
its alot smaller, lighter, alot more venting for heat and its got 2 fans one on each side. very pleased with the outcome!
2005 Subaru Outback
Old 04-08-2010, 10:00 PM
looks like a good idea, what mp is it rated at?
Old 04-09-2010, 09:42 AM
Porsche Enthusiast
havnt posted something in awhile but i just got done with "project ass end". i dislike the rear end very much so decided to smooth it out a bit. still under construction. check out the pictures.
2005 Subaru Outback
Old 08-21-2010, 08:04 AM
Nice fart can exhaust. I'm sure all the Honda boys will be super jealous.
Old 08-21-2010, 01:58 PM
doabarrelroll's Avatar
What is the model number of that alternator and what does it take to install it?
944S --> 944 turbo S - 2.5L Dry Sleeves, K26/8 Turbo, LR Height Adjustable Motor Mounts (-1/2 in.), LR 3 Piece Xmember, LR 3 Piece Xover Pipe, LR Oil Pan Baffle Kit, 930 Clutch, Lightened Flywheel, Custom RX-7 Oil Cooler, Apexi EBC, Tial 38mm Wastegate, Full 3" SFR Exhaust, etc...
Old 08-21-2010, 02:46 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
