Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
89-951's Avatar
951 Problem
New to the forum, hello all.
I have an 89 951 that overall runs well. On the freeway or at any constant speed requiring little throttle there are random brief losses of power. Like a quick shutter.
Also, on one instance when the car started it stalled a few times in a row under any amount of power.
Have ran a new fuel supply line recently and also new wires. Putting in a new fuel pump, fuel filter and DMW relay in this weekend. If it doesn't fix the problem was thinking of replacing the plugs, not that old.
Any other suggestions??
Thanks!
Old 05-01-2010, 01:43 PM
In the Fires of Hell.....
kdjones2000's Avatar
I would check your Air Flow Meter/AFM. I am thinking that the barn doors are not opening/closing smoothly, or the resistance is not linear.
I think that Clarks Garage has a procedure to check it: Clark's Garage Home Page
Good luck, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 05-02-2010, 02:41 AM
89-951's Avatar
Thanks Keith!!
Old 05-02-2010, 08:18 AM
choinga's Avatar
could be your TPS as well - same kind of 'tracks' that can wear and cause problems...if it's not adjusted properly it will cause issues like this.
Old 05-02-2010, 10:57 AM
89-951's Avatar
Thanks! Will let you know WHEN it is running properly, probably won't have time until this weekend to get into it....
Old 05-05-2010, 04:04 PM
