Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Yellowb1rd's Avatar
Anyone know what this part is???
This ancillary will not stop running, even after the engine is turned off. I actually discovered it when I was in the garage the day after I took it out for a drive and noticed a churning noise coming from the engine compartment. I located it easily, and disconnected the power coupler leading into the part, and it stopped. As soon as I plugged it back in, it came right back on again. Can anyone tell me what this part is, and what it does? I've included a photo with the a red circle around the component in question.
Old 06-09-2010, 04:10 PM
Yellowb1rd's Avatar
a little easier to find in this photo
Old 06-09-2010, 04:19 PM
Yellowb1rd's Avatar
Old 06-09-2010, 05:14 PM
That Guy
Techno Duck's Avatar
Turbo waterpump, it will run for aprox. 30 seconds after you shut the car off or until water temp in the turbo waterjacket lowers to a certain point.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 06-09-2010, 05:56 PM
Yellowb1rd's Avatar
AH, ok. So if it isn't stopping, even after the engine is cold, then would it be the switch, or thermostat that would need checking?
Old 06-09-2010, 06:09 PM
That Guy
Most likely thermostat. The connector for it is the black cap with single wire coming out of it under the throttle body area, right by the TPS. If you disconnect it and the pump stops, thermostat is bad. If you disconnect and it keeps running, the relay is probably stuck.
Jon
Old 06-09-2010, 06:31 PM
Super Moderator
nize's Avatar
lots of threads on here detailing how to troubleshoot the turbo water pump.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 06-10-2010, 10:29 PM
Born2bwild1191's Avatar
Mine wouldn't stop running either, it was the relay.
'87 Guards Red 924S - First Porsche - SOLD 5/21/10
'67 Red VW Beetle - Restored by me and my dad, 2115cc motor.
'87 951 - Silver/blk, full leather interior - LR Chips - 3 bar FPR - LBE
'92 Ford F150 - Winter truck
'04 Yamaha R6
Old 06-15-2010, 06:40 AM
