Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Brake Fluid Guru
Running WAAAYYYYYY Rich. Where do I start?
Well at the ole' 951 at the CA Smog station and as I expected, it didn't pass. I figured such as my fuel mileage has been steadily decreasing I have assumed it was running rich. Well I was spot on with that assumption. In fact it's running so rich the car is WAAAYYYY in excess of even the CA "Gross Polluter" standard. Specifically, the CA state max for HC (in PPM) @ 15 mph is 115, the GP is 308 and my car measured 402! At 25 mph (in the same order) 75, 258 and 247.
Obviously there is something wrong here. I have replaced the plugs, the cat and the O2 sensor as well has just changed the oil. I have a new rotor and cap but haven't installed yet.
So the question is, where do I start to look/replace parts in trying to remedy this situation? FWIW, the ecu is stock and came from Rogue Ant last year.
Any and all suggestions are welcomed and appreciated.
Michael
Michael
Old 08-03-2013, 09:34 AM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Porsche Crest Check Fuel Regulator & Dampner
Boostbuggy;
I would check them both with and without vacuume. The oem should be at ~36psi or 2.5bar at idle 840rpm. They have a tendency to get stuck.
I would upgrade to an adjustable FPR form Lindsey Racing <Dave>.
Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 08-04-2013, 08:06 PM
Brake Fluid Guru
And how does one do that? i.e. chk the FPR and the Damper? And where are those two parts? Sorry, this is new area for me and I'm really not familiar with what the parts are and/ore where they're located/look like.
Thx
Michael
Old 08-04-2013, 08:10 PM
That Guy
Techno Duck's Avatar
Check your fuel pressure at the rail. This will determine if the fuel pressure regulator is bad or not. Check condition of the vacuum line for the regulator also.
Replace the DME temp sender, it is inexpensive and easy to replace (i wouldnt waste the time to test it) and will cause rich running conditions.
Another possibility is the AFM is out of adjustment, check the above two first as they are the most likely.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 08-04-2013, 08:30 PM
Brake Fluid Guru
How do you chk the FPR? As the car has 227k on it I don't mind just replacing easy inexpensive parts like the DME Temp Sensor but with the FPR being more like $100+ I'd rather check it before replacing.
Michael
Old 08-04-2013, 08:50 PM
That Guy
You have to check fuel pressure at the rail, this will tell you if the regulator is bad or not.
Jon
Old 08-05-2013, 08:45 AM
Banned
Originally Posted by guru944 View Post
Boostbuggy;
Later...
fuel pressure according to clarks-grage is supposed to be 29 psi at idle. 36 psi is when jumpered.
Old 08-05-2013, 08:53 AM
