Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Unhappy Uh-Oh.......
I went to do a second oil change today, and I found a .060" ball bearing attached to my magnetic drain plug.
Where the %*&# did that come from?!?!?!!
I already spoke to Vic about the Garrett turbo- the bearings in those cartridges are more than double that size. The check valve in the head is also MUCH larger. Those are the only ball bearings I know of in the entire motor. Where could this be from?!
Old 09-23-2010, 12:55 PM
your average wrencher...
interesting....I have no clue
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 09-23-2010, 04:21 PM
Man that scares me.
Swiped around a little magnetic whip as much as I could through the drain hole. Nothin. This might remain a mystery.
Old 09-24-2010, 02:01 AM
968 GUY's Avatar
Is that about the size of the ball behind the fuel test fitting cap?
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 09-24-2010, 01:35 PM
Could it have been attached to the magnet when you installed the plug? Have you done any work with that size ball bearings lately?
BTW. Aren't there a ball valve in the lifters?
1990 944 T: 100 000 km/63K miles,
1997 986 2.5L: 95 000 km/60K miles,
Living in the trackless land of plenty!
Old 09-24-2010, 02:11 PM
And the plot thickens. Only the Shadow knows. THINK, MAN, THINK!! Have you been spending more quality time with your car than with your wife or girlfriend or both? A woman can be extremely devious at times. One single small ball bearing found where none should be found will drive a man crazy or to drink.
Cheers,
Larry
Old 09-24-2010, 04:35 PM
Where is the fuel test fitting cap?
And good point about the lifters...I was just looking through a thread the other day about dismantling them to see what they contained.
I'm not sure my girlfriend is that devious...or stupid. I told her I would spend much more time with her when the car was done...so she would be hanging herself there.
I doubt it could have been attached to the plug before I put it back in. I clean the hell out of those plugs when changing the oil. And I hadn't been working with ANY ball bearings over the engine when I rebuilt it. My only thought is that maybe it was stuck in the plastic baffle in the pan from before. I never removed the baffle because the bolts were loctited on and just wanted to break. So I swilled a bunch of kerosene through it and called it a day when it came back clean.
Old 09-25-2010, 06:23 AM
KEV951's Avatar
thats just plan old foreign particle contamination, it somehow made it in your engine, who knows? you were doing an oil change maybe the filler cap was off and the neighborhood kid shot his bb gun in the air and guess where the bb went, There is no small bb anywhere in the engine , if you lost your fuel pump check valve bb , you will have hard starts almost everytime and there is almost no way for it to get into your engine unless one of your injectors has a hole the same size as the bb in it now. Or, same senario, you put your drain plug down when draining oil and there just happened to be a bb in the area which stuck to the magnet on plug and maybe you didnt notice it when you put it back in? Or worst case , some a-hole is trying to destroy your motor when you werent looking or if the car had ever been in a shop . There are about a trillion other possibilties, these would be the most frequent imo
Old 09-26-2010, 10:23 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Remember that last ricer you soundly thumped? He put it there....for revenge
BTW, if any of your fuel injectors were able to pass an object that large, it would be like flushing a toilet over that cylinder
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 09-26-2010, 11:31 AM
Thanks for the reassurance guys. I will drive her...carefully. And do the next oil change much sooner to check for any more surprises.
And obviously, be more careful next engine rebuild.
Old 09-26-2010, 12:34 PM
