Headgasket
What is the proper headgasket to use with a 2.7 liter motor? Part #? It's a Turbo with sleeved pistons. 104mm bore i think? Thanks.
Minh |
The motor has been stroked and not bored?
If that is the case, I think you would just go with the same gasket: Porsche part no: 951 104 374 02 (standard) 951 104 374 50 (for resurfaced head) If you have the head off, I would look into a wide-fire head gasket. -G
Geoff Baltz - St. Louis Region PCA Board Member/DE Chairman PCA HPDE Instructor |
Sorry my last post was off. Sleeved block. Bigger bore. 104mm
