Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
944 turbo suspension upgrade
I have a 944 turbo with stock suspension, and I've been getting really into drifting. My car has an immense amount of body roll. So I'm looking to upgrade the suspension.
I wanted to get coilovers, but they're really hard to find, and decently expensive.
Soni was looking into upgrading the torsion bars, front springs, and all 4 shocks. What would be the stiffest setup I could do with this? Is 30mm the largest? And what is 30mm expressed as a spring rate?
Thanks, Taylor
Old 11-30-2010, 12:26 PM
winter-hater club member
nynor's Avatar
try here:
Koni, cup, coil, over, kit, 8641-1414, 8040-1035, 30-series, 8641-1038, Bilstein, Escort ,Cup ,Coil, Over, Kit, fire, hawk
$1400 for a full koni coil over kit. i don't think it gets much better than that. it comes with all four shocks, whatever springs you want, etc. you can then delete the torsion bars (although some are very against doing this, and i really don't have an opinion yet nor have i done any research).
"COOL PRIUS!" - Nobody Ever
Old 11-30-2010, 03:48 PM
I was looking into that, but it's way out of my budget. I was looking so buy some used stuff.
Old 11-30-2010, 08:12 PM
That Guy
Techno Duck's Avatar
30mm torsion bars work out to be about 335lbs wheel rate. I think the biggest torsion bars i have seen are 31mm, but they may have been hollow which if i remember right has the same rate as a 30mm solid bar.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-30-2010, 09:21 PM
Oh alright. I guess I may have to go with coilovers. I want to do around 550-600 in the rear.
Old 12-01-2010, 04:01 AM
nynor's Avatar
if $1400 is out of your budget for a full coilover setup, i don't know what to tell you. if you are going to install used shocks and struts, etc., that is not the best plan. don't get me wrong, i understand having a budget.
Old 12-01-2010, 06:08 PM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
Save up $1400 and do it right.
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 12-01-2010, 07:45 PM
