Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
951mw's Avatar
Crank Breather tank by Lindsey racing??
I have been looking at the CRANK BREATHER TANK kit by Lindsey racing for my 951 but I wanted to hear from members that have used this system. So for those of you who have used this system on your car. What is your overall impression? What do/don't you like? and would you buy it again?
BREATHER TANK at LINDSEY RACING - Your Porsche Performance Parts Center
Old 01-23-2011, 06:58 PM
KEV951's Avatar
I like a sealed recirculaing system better, NO MESS under boost, but the LR will work fine.
Old 01-24-2011, 10:04 AM
your average wrencher...
try: Unknown Location....Scary!!!
it will recirc. then.
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 01-24-2011, 06:00 PM
Super Moderator
nize's Avatar
i bought a saikoumichi can and decided to stay with the lindsey can because the saikoumichi unit does not open/separate, so there's no way to inspect/clean the inside of the can.
if saikoumichi had a screw-on top it would be a better choice.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 01-27-2011, 11:22 AM
951mw's Avatar
thanks for sharing. also how full does it get after a day at the track? I'm just trying to figure out if I'll need to bring another container to pour it into at the track or if it can wait until I get home.
Old 01-30-2011, 10:29 PM
choinga's Avatar
yeah, but it's not messy.
And, if you rig it up right, you can have it off with a single bolt (I bolted mine to a spot where the stock airbox was attached). There's a screw at the bottom to drain.
1987 951 - SFR 3" exhaust, Vitesse MAF w/ 83# injectors, Vitesse S2R Turbo, Tial 38mm, Lindsey MBC, Spec Clutch w/ Fidanza flywheel, Turbo S Brake Kit w/ Drilled Rotors, Koni shocks, 17" Michelin PS2's on Fikse FM5's, Saratoga Sunroof.
Old 01-30-2011, 10:46 PM
That Guy
Techno Duck's Avatar
The amount you get in the can depends on some factors such as how well your crankcase is sealed (air / oil seperator o-rings and associated hoses running to the j-pipe) and how much blow by is getting past the rings.
My engine i would consider relatively healthy with 125k miles and usually i empty it every oil change (3-4k miles), accumulation is about 1/4 of a water bottle at most. It is mostly water with a little bit of oil mixed in.. looks like iced tea .
BTW, this is with the Saikou Michi catch can.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-31-2011, 10:31 AM
Why is catching it advantageous to having the vapors pass back through the engine along via the intake air? Someone please explain. I realize that when you suddenly close the throttle after a boost session, there might be momentary (until BOV opens) positive pressure that would pass to the oil separator but other than that, I don't see a problem with it.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 02-02-2011, 07:19 AM
That Guy
The oil vapor being sucked through the intake track effectivley lowers the octane rating of the fuel mixture.
Also another advantage is that it keeps the intake tract much cleaner. Previously i would get a film of oil on almost everything from the compressor blades, charge pipes and intercooler. Not anymore.
Jon
Old 02-02-2011, 09:16 AM
OK, it lowers the octane number of the fuel mixture. That would be very much a function of how much pressure drop you get across your air filter as well as the crankcase pressure due to blow by.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 02-02-2011, 09:50 AM
951mw's Avatar
For an average DD car this is not much of an issue. But if you track your car I have noticed that you start to get film built up in things like the intercooler which then make the intercooler less efficient that then robs you of HP.
Old 02-02-2011, 10:41 AM
