Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
1987 951
2001f4s's Avatar
Any chance I can crowbar these on to an 87 951??
Sorry to be lazy here. But hoping someone can help me.
Any chance these would fit without looking to "rice racer like"
19x8.5 et54mm offset front and 2 19x11 et62mm offset rears, 5x130 bolt pattern
Old 01-20-2011, 06:54 AM
Quality
phoenix_iii's Avatar
18''s aren't even recommended, let alone 19''... why so much wheel?
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 01-20-2011, 07:33 AM
1987 951
2001f4s's Avatar
seemed like a good deal, but if they don't fit....
Old 01-20-2011, 07:35 AM
Quality
Bad deal for your suspension/bearings/everything. =) Stick with 16s, 17s, or 18s if you must (but need to make suspension changes accordingly, see the Porsche document that is in various threads)
Old 01-20-2011, 08:50 AM
1987 951
2001f4s's Avatar
Thanks Phoenix, appreciate the insight
Old 01-20-2011, 09:02 AM
1987 951
2001f4s's Avatar
Continuing to lean on you guys for input on the wheels sizes here.
Any thoughts on how well these would fit my 87 951:
7.5J x 18--ET 50
Part No: 993-362-120-03
10J x 18--ET 40
Part No: 993-362-134-06
Old 01-24-2011, 08:30 PM
1987 951
2001f4s's Avatar
TTT
Any help with the last inquiry would be great.
Old 01-25-2011, 08:54 AM
That Guy
Techno Duck's Avatar
The rears will probably not fit right. The 40 offset is really low (causing the wheel to stick out too far) and will more than likely rub on every bump you hit and on heavy acceleration with the rear end squat. Tire brand and width has a big factor in this, but the wheel to begin with is just not the ideal fitment.
The fronts will fit.
Generally speaking for a late offset car, you want in the mid 50mm offset range for the front assuming a ~8-9" front wheel and around a 60-65mm offset in the rear assuming a 9.5-10.5" wheel. This is obviously+/- a few MM both ways, but i can tell you from experience 40 in the rear is way to low.
From experience, i have run a 17x9.5 rear with a 46 or 47 offset (i forget exactly) and it rubbed very badly with a 275 width rear tire on bumps and even medium acceleration. The 18x10 you posted will be even worse.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-25-2011, 10:15 AM
Got boost?
derekc23's Avatar
The 40 rear would work best on an early offset car like my '86. Techno Duck really did a nice job of summarizing what you'll need for your '87.
1986 951, 89k miles, CCW Classics (black) 17" x 10" (275/40) & 17" x 9" (255/40)
Old 01-25-2011, 06:19 PM
1987 951
2001f4s's Avatar
Techno Duck,
Thank you much. That is just the information I was after.
Much appreciated.
Scott
Old 01-25-2011, 07:37 PM
1987 951
2001f4s's Avatar
Still searching for some wheels that will fit my '87 951.
Another question on the rear wheel. Looking at a set of 18" diameter wheels where the rear states the following:
9Jx18-Et 52 "B" and 10Jx18-Et 65 "A"
So I know from what I have learned here that the 65 offset should work well in the rear, but I am not sure how one wheel can have two different offsets. Is this based on the tire width.
The fronts are: 7.5Jx18-Et50
Any help would be great.
Old 01-31-2011, 12:38 PM
That Guy
So the two rear wheels are different widths?
The offset is dependent on the width of the wheel. Take a hypothetical situation involving a 9" and 10" wheel with the same offset of 55mm. Say the outside of the 9" wheel sits 1" away from the inside of the fender lip. Now the 10" wheel will sit approximate .5" farther out on both sides of the wheel, effectively cutting down the amount of clearance between the wheel and fender lip (body of car) by .5" on both sides of the wheel. There is a sweet spot of where you want the centerline of the wheel to be in order to maintain maximum clearance on both sides of the wheel well..most times you can continue to push the wheel inward as there is plenty of space in the wheel well. So by raising the offset of the 10" wheel to say 65mm you are now bringing the wheel back in by approximately .4" (or 10mm) . So effectively the wheel now sits .1" (give or take) closer to the outter fender lip, and .9" farther inwards. The limit of this on a late offset car is a 11-11.5" wheel. As you basically have no space inside the wheel well anymore. The widest i have seen on a car with stock bodywork was an 11", and yes this required pretty much a spot on offset.
I run a set of 17x10.5" wheels on my car and while i dont remember the exact offset, its 65mm or 67 if i remember right.
Jon
Old 01-31-2011, 08:35 PM
1987 951
2001f4s's Avatar
Techno Duck,
First off thank you for the patience and the explanation.
I do apprecaite it.
According to the seller each of the rear wheels have both of these two markings:
That is where I am confused.
It might be that the seller is confused as well.
Old 01-31-2011, 08:48 PM
