Airbag wheel to Momo
I am trying to remove my airbag wheel and put on a Momo wheel. I have bought the correct adapter (7004) I think. The problem is both the adapter and mounting surface (blinker control cluster) both have a "ring". One of them needs to have a "brush" in order to maintain contact. Do I have the wrong adapter or do I need to change the control cluster to one out of a non-airbag car? TIA
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
That Guy
I explained how to do it in post #140. Basically the cruise control multifunction switch can be modified to accept the horn contact piece. 1 hole just needs to be drilled.
Another project thread - Page 10 - Reutterwerk Forums
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
thanks.. do you know if a pre airbag multifunction one will work. I could get one really cheap
That Guy
I am fairly certain it should work fine, i opted to go the other method as to save money on a new multifunction switch (think with cruise it was about $180). The horn contact was cannibalized from a spare non airbag multifunction switch with worn out labels on the stalks.
The non-airbag assembly also uses a different plastic cover (mounting holes are in different spots) so make sure you get one of those also.
here is a link to a rennlist post that goes over how & what is needed to make the horn work:
Replacing Airbag steering wheel w/ non airbag - Rennlist Discussion Forums |
thanks guys, helpfull, I should be all set now
