Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
74goldtarga's Avatar
Can Lindsey Boost Enhancers Fail?
Does the LBE fail, if so how would you know, what would happen? Does it need to be maintained? Is there a way to test if it is working?
Thanks.
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 03-14-2011, 08:56 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Can't see how it can fail, if I'm not mistaken, it's basically a hollow tube with an adjustable pressure restricter inside. Does not require any maintenance. May be possible that the nylon poppet or the nitrile seal goes bad. Call Lindsey and talk to Dave
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 03-14-2011, 11:25 PM
Architect / Car Guy
carlege's Avatar
Send a message via AIM to carlege
if it fails it could make your car will work as it did before you had it. Basically you can adjust it to show higher boost and that would prove its still working. the normal boost setting is the thickness of 4 pennies.
Looking Forward to getting my First "car" Porsche 951
Old 03-15-2011, 02:58 AM
Quality
phoenix_iii's Avatar
Mine was missing the spring (blame the PO). Emailed D. Lindsey for a replacement spring but no reply (yet... it's been almost a week). Was allowing 'unlimited' boost (20+psi), couldn't blow through it.
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 03-15-2011, 05:43 AM
mcarter's Avatar
Mine too was missing all its guts...PO.
Dave at LR sent me the inners. Just a few pieces...didn't cost much!! Came with instructions. Works fine.
Old 03-15-2011, 07:34 AM
