-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Turbo alignment problems (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/596776-turbo-alignment-problems.html)
tayloray 03-13-2011 08:48 PM
Well my turbo got destroyed by a bolt, so I bought a used one, and before install I took the housings off and cleaned it. I forgot to mark the clocking. So I'm trying to test-fit it but no matter how I turn the cold side housing with it put together loosely, I can't seem to get the oil return on the bottom, and the crossover flange to both be aligned.
rick13 03-13-2011 08:53 PM
here are some pics. this is what i used to put mine back togetherhttp://forums.pelicanparts.com/uploa...1300074685.jpg
http://forums.pelicanparts.com/uploa...1300074732.jpg
http://forums.pelicanparts.com/uploa...1300074775.jpg
http://forums.pelicanparts.com/uploa...1300074821.jpg
rick13 03-13-2011 08:55 PM
note the dimple on top. also check out the other "stamps" and markings for reference.
good luck,
rick
tayloray 03-13-2011 09:06 PM
Thanks! I just based it off those, well see if I got it right
bebbetufs 03-14-2011 01:20 PM
I cannot see the frame for the extra serial no plate on the back of the cold back plate. This indicates that it is covered by the outlet flange. This has to be mounted differently, away from the turbo mount. The frame protrudes enough to prevent you from mounting the turbo to the car. There should be a x stamped on the inside of the backing plate marking the trouble spot.
rick13 03-14-2011 03:31 PM
http://forums.pelicanparts.com/uploa...1300141843.jpg
rick13 03-14-2011 03:33 PM
sorry, i cant find any more pics
tayloray 03-15-2011 12:46 AM
Bolted up perfect, thanks again.
