Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Guest
i have no heat
Hey guys, my car (87) has no heat blowing out of the vents. The a/c works fine though. Any ideas?
Jordan
Old 02-12-2002, 07:49 PM
Since you are getting cool air out of the vents, I would check to see if the hot water valve is opening and closing. The valve is located just in front of the firewall near the block. Notice if the valve moves when heat is called for. Notice if the lines are equally hot on both sides of the valve indicating valve is open. Also check fuses.
Old 02-13-2002, 04:19 AM
