Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Finishing clutch replacement...My crank won't budge
Hello all,
Today I bolted my flywheel, clutch and pressure plate in. I wanted to spin the pressure plate to reach the bolts on the top of the plate, and I found that it would not budge. I even tried turning it with a breaker bar at the crank, and it won't move in any direction.
When removing the old components, I could spin everything by hand. Per Clark's Garage, I had been bracing the crank against the ground with the breaker bar to remove the flywheel bolts.
Thanks to a debilitating car accident, this clutch job has lingered on too long.Any ideas? Please help!
Old 03-30-2011, 02:23 PM
Problem solved.
Old 03-30-2011, 05:05 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
what was the issue?
Mike - Flight Instructor, A&P Mechanic, Fuel Injector Service Specialist
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
'99 VW Cabrio - green/tan - daily beater
'83 944 - zermatt silber/black - Dad's 40k mile time capsule. purchased in 09-1998 @ 18k
Old 03-30-2011, 06:02 PM
a rubber hose, obscured from view, got stuck behind the flywheel. Lol
Old 04-14-2011, 10:51 PM
ERAU944's Avatar
oh my. sometimes it's the simplest little things that hold up the whole project, what a pain!
i'm glad you found it, and even more glad that you can laugh at the error!
drive safely!
Old 04-15-2011, 05:01 AM
Tags
clutch , clutch installation , crank , crankshaft
