electrical drain
Battery goes dead overnight. many symptoms. Radiator fan runs, but the oil pressure gauge spikes and remains pinned while key turned, and while engine running. This one causes concern. What would cause that?
winter-hater club member
if the oil pressure sender wiring is on backwards it will peg the pressure gauge.
as for the drain, could be a lot of things. i have one i am chasing. it takes a few days for it to drain my battery. i've read that the clocks will drain batteries. the turbo pump. a fan keeps running at low speed. it could be a light that is left on inside the glove box or in the trunk.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
