Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Yellowb1rd's Avatar
What part is it????
Ok, this is driving me crazy. My 87 944 Turbo is missing a trim piece that I cannot identify. Water and the elements bombarding the engine bay, especially the battery. It looks like there is a plastic trim piece missing that I've been trying to find on pelican's site, but have not been able to. Basically, I can see the battery and the terminals when I'm looking down at the base of the hood (on the windshield side). Does anyone know what this piece is? Its kind of tough to describe the piece, but again, it seems like it would be some sort of plastic trim. Can anyone help?
Old 06-11-2011, 07:13 PM
If it is the thin black plastic piece that covers the Air Blower Motor it is called "Cowl Cover". It runs around $90.00 from a Dealer + s/h. Fit from side to side, under the w/shield to firewall.
http://www.944online.com/cgi-bin/ASI_Store.cgi?Product+skukey_1116944474+9442+body-9442
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 06-11-2011, 07:43 PM
Yellowb1rd's Avatar
That looks like it may be it!
Old 06-12-2011, 02:06 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Even if this is the missing trim piece, you are still going to get water, rain and crud into this area, since this trim piece does not seal the area. There is a drain located in the corner of the battery compartment you will need to unplug if you have standing water in this area (there is also one located on the drivers side in about the same position).
Make sure you clean out the accumulated dirt, leaves, paper etc when clearing the drains. I make it a habit to run a stiff piece of wire through these drains and the drain located below the fuel filler neck every few months to keep them from clogging.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 06-12-2011, 09:02 AM
Yellowb1rd's Avatar
Seems like a poor design from the factory, since the battery terminals are exposed to the elements.
Old 06-12-2011, 11:24 AM
Here is the battery cover.
Pelican Parts - Product Information: 477-915-411-A-OEM
Cheers,
Larry
Old 06-12-2011, 10:09 PM
