-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   What MPG do you get in your 951? (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/612751-what-mpg-do-you-get-your-951-a.html)
MarkRobinson 06-07-2011 01:11 PM
I average about 20mpg in the city driving like a grandma (gas is $4/gallon here for 93), running consistently on a 10-gallon refill to keep the car light. No spare tire or tools to weigh me down, but do have 285mm rear, 245mm front tires.
On the highway this last weekend, I did 600 miles @ 21mpg average, 65-70mph, lots of hills, full car (600lbs of people, gas, luggage, dogs)
In the city, with just me or me & the misses in the car, I average about 20 in granny-mode.
My car has rebuild injectors, 928 pump, Vitesse chips with an adjustable FPR running 30psi fuel pressure (no, I don't get on boost at all with it 8psi low)< but found a semi lean & clean 15.5:1 at cruise which is about as lean as I can go w/o feeling the reduction in fuel.
I ran 31psi down there for 20mpg, 30psi back for 22mpg, but it's bordering on way too lean & of course, I don't dare get on boost like that.
Just curious to see what others are getting.
billy mild 06-07-2011 01:19 PM
I get 23 mixed highway/city 50/50 mix. Straight highway doing 80 MPH I got 28 MPG.
With the turbo mill in these cars you can get 28 mpg. That was just me and a passenger plus our bags oh and no A/C cause mine is broke.
MarkRobinson 06-07-2011 01:24 PM
Interesting. I tried 10 gallons a month ago with one gear higher: ie, always between 2700-3300rpm, both city & highway: my MPG dipped down to about 19. I was thinking that since engines are more efficient, maybe the efficiency over-rides the extra fuel needed to sustain the higher RPM, but appears to be invalid.
Normally, I'm low RPM & high vacuum.
944 Ecology 06-07-2011 01:36 PM
On a California to New York trip, 25 mpg highway at 75 mph. Moderately loaded, no passenger.
UncleRay 06-07-2011 05:49 PM
Mileage on trips with city and highway average in the high 20's to 30 mpg. There is more info in this thread...http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/590862-951-fuel-mileage.html
Pete R 06-07-2011 05:52 PM
I did my first track day the other day. I went 70 miles and used pretty much the whole tank. It's probably in the 6-7mpg range. :) that's probably not the info you were looking for though
derekc23 06-07-2011 06:00 PM
I've been getting mid 20's on the highway but it's been a long time since I've driven it long distance much less around town until this past week after it sat in the garage all winter.
tyro 06-07-2011 09:03 PM
~23MPG in mixed city driving.
On a trip to Road America a couple of years ago I managed 32MPG, once there and on the track..6MPG.
zedsn 06-08-2011 03:06 AM
Generally 15 mpg city and 20 to 25 mpg highway but depends on how heavy my foot gets.
MarkRobinson 06-08-2011 05:49 AM
At times I can smell fuel, but is always fuel-vapor free under the hood & yes I've changed out my hoses. Wonder if I have a leak out back??? :(
968 GUY 06-08-2011 01:14 PM
I replaced the cam tower gasket recently, was getting just below 20mpg before, now I have
driven it only 90 mi. or so and used half a tank. This car is all orig. equipment except for boost enhancer that I have set per instructions from Lindsey.
Nothing seems to be wrong, no excess gas smell, runs well, new plugs, wires, cap, injectors sent to witchhunter for cleaning etc.
Guess I need to do a bit more poking around.
tyro 06-08-2011 05:50 PM
Do you have a wideband? 14.7 air:fuel at idle and cruise?
If the oxygen sensor is out of order, the system goes rich.
running_cold924 06-09-2011 05:06 PM
consistent 26mpg...
Dougs951 06-09-2011 06:12 PM
22-28 depending on how I drive it.
Well that and the weather.
89-944NA 06-09-2011 09:23 PM
0, ZIP, NADA, NO MPG.....Car is sitting until I get 2 more project cars out of my garage. Then I'll have the time and space to freshen mine up. Actually, was getting about 27 highway, about 20 city.
Lawrence Coppari 06-10-2011 08:51 AM
I get 30-31 driving about a steady 65 mph with car fairly heavily loaded and TP at 37 psi. The best I get in town driving is 23+. On the track it gets 6-7 mpg. I have a k27, 3 bar fuel pressure, MAF. Three years ago my O2 sensor went bad and the highway mileage dropped to about 25. With a new O2 sensor, it popped back up to 31 ish. Fuel injectors have be professionally serviced.
shavinseconds 06-13-2011 08:48 PM
18 in the city. ..I definitely want to get more without driving like a snail. ..
Lawrence Coppari 06-14-2011 10:35 AM
My town driving is nothing like city driving. I don't think I'd get 23 in a 'real' city.
MarkRobinson 06-14-2011 12:32 PM
i just replaced my AFM with another Ohm'd good one: so we'll see how the next tank or to does.
wild man 06-24-2011 02:50 AM
The only way to get better fuel economy, is to run skinnier tires - but who wants to do that?
