Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
DinoDanny's Avatar
This is strange
I walked out into the garage this morning and hear a humming noise coming from under the hood. I assume that its the turbo coolant pump running. I pop the hood and see that the coolant in the expansion tank is bubbling and gurgling. The car hadn't been started for over 24 hours when I had just finished washing the engine bay. Anyone have any idea whats going on?
Thanks.
Danny
1987 Porsche 951
2003 Kawaski ZX-12R
2008 Kawasaki Concours 1400
Old 07-22-2013, 08:47 AM
Only two? Wires going into the after run pump. You have a short or a bad sensor.
Old 07-22-2013, 10:10 AM
DinoDanny's Avatar
Yeah, its definitely the cooling pump. I think it must have had something to do with washing the engine bay since I didn't have the problem before
Danny
1987 Porsche 951
2003 Kawaski ZX-12R
Old 07-23-2013, 05:34 AM
There is no substitute..
FRZ951's Avatar
Remove the relay.. test it.. you be fixed! The pump is suppose to run 30secs after the engine shutdown.. and then stop.
--Matt
I couldn't find the sports car of my dreams, so I built it myself
Porsche 951 1988 - More than 305 RWHP & 350 RWTorque
Old 07-23-2013, 03:23 PM
DinoDanny's Avatar
Got everything dried out and the pump is shutting off like it should now.
Danny
1987 Porsche 951
2003 Kawaski ZX-12R
Old 07-23-2013, 06:31 PM
Most likely a wet cable on the temp-sensor shorted the plug to ground and triggered the relay to run the pump.
The turbo water-pump relay doesn't initiate anything, it only responds to inputs. Two triggers set off the relay to power the pump for 25-seconds. The first trigger is power-OFF when the DME relay cuts power when you turn the key to OFF. This triggers the relay to run for 25-seconds.
The 2nd trigger is the turbo water-temp switch/sensor, which grounds the sensor wire at 244F. This triggers the relay to run the water-pump for 25-seconds. After that, the state of the sensor-wire determines what happens next. If temps are still above 188F, the sensor still grounds the wire and the relay will still run for another 25-seconds. Then the sensor-state determines what happens next, >188F, wire is still grounded and water-pump continues to run... etc, etc, etc. The sensor is a fan-switch, it goes ON and grounds at 244F, then goes OFF and disconnects at 188F. Anything in between that after the initial 244F and the water-pump will still be running.
It's an OR circuit that triggers the relay for 25-seconds:
1. DME-relay power to injectors/fuel-pump is ON then goes to OFF
OR
2. turbo water-pump sensor hit 244F AND is still above 188F.
BTW, the pump is a low-load motor, it takes about 3-days to run down the battery.
Old 07-25-2013, 07:14 AM
