Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
There is no substitute..
FRZ951's Avatar
Sparkplugs fuel PROBLEMS
moved to here: Lindsey Racing chips
--Matt
I couldn't find the sports car of my dreams, so I built it myself
Porsche 951 1988 - More than 305 RWHP & 350 RWTorque
Old 09-11-2011, 11:01 AM
Either the DME chip or the KLR chip is bad... go back to square one and reinstall the original chips, make sure that the car starts, then install the DME chip and check to see if it starts. If it doesn't, it is the DME chip that is bad.
If it does start with the new DME chip, install the KLR chip and see if it starts. If it doesn't, it is the KLR chip.
Good luck, George Beuselinck
Old 09-11-2011, 02:51 PM
FRZ951's Avatar
Ok I just came back from getting new plugs. I go install them right now and try start the car with both original DME & KLR chips, which was working #1 before.
--Matt
Old 09-11-2011, 02:53 PM
FRZ951's Avatar
Well.. still no start with fuel in the spark plugs hole. All cylinders...
I drained the hole with a hose. But now I dont know what the problem should be.
--Matt
Old 09-11-2011, 03:32 PM
Is the fuel rail installed properly and the injectors seated? Hate to ask, but fuel in the plug sockets sounds suspiciously like an injector leak
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 09-11-2011, 07:45 PM
JJK78-951's Avatar
You REALLY need to see if you are getting spark. New chips are not going to throw excess fuel at it, there is excess fuel because you are not burning it.
Check for spark then post back.
John~
2003 996 Turbo... 128K Daily-ish
2000 Accord V6... 275K - 65K motor/trans now given new life!
Old 09-11-2011, 08:01 PM
