Hesitant acceleration
Hey guys. I just bought a 1986 turbo a couple of weeks ago and i am loving it (sure beats a '92 volvo wagon)! Anyway im feel the car hesitates a little when she is pushed. I cant tell if its only in certain gears or not.
There is a performance chip installed (i cant remember what kind) and there appears to be exhaust work done. The previous owner did say he did some work on her and provided some paperwork which i have yet to go through. Initially my thoughts are bad chip, something wrong with the turbo, or maybe some kind of fuel delivery problem. This is my first turbo so im still under the learning curve. Any suggestions? Thanks for your help! |
Start with the basics and verify that you have good plugs, rotor, cap, etc. Not sure exactly what type of problem you are having, but mine had a surging/ miss during hard accelleration and I changed the plugs to the NGK BPR7ES, and it made a world of difference. NGK's seem to be better than Bosch. Make sure you do not have platinum plugs or any of the other gimmicky plugs that are being marketed. These cars run best on the old style copper single electrode plugs.
1988 944 Turbo Guards Red - Black Leather Autothority Stage 2 Chip Set Weltmeister Strut Tower Brace 1984 944 - Sold to rcecale |
Did the car sit a long time? I had a hesitation when I first purchased my car. Brand new gas fixed it. Worth checking out before you start tearing into stuff
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Its my daily driver so ive put 2 or 3 new tanks of gas in her.
In the Fires of Hell.....
Very hard to discern what you mean by that statement.
Any turbocharged car will have some "Lag" when you hit the gas pedal, while the turbocharger spools up. Once the turbo is spooled and the engine is in power band, there is a rush of acceleration. On 951's with their (relatively) larger turbos, lag can be quite pronounced. I liken it to an elastic band being stretched and released, if that makes any sense. If you are saying that you are getting chugging or some other lugging while in power band, then it is probably due to other things such as vacuum leaks, fuel delivery issues, A/F ratios, etc. Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Having gone through some bad gas recently, there is a difference between hesitation from gas, vacuum issues etc.
As kdjones notes, turbo lag, is that whumph feeling when the turbo spools up and the car launches forward. Some more questions: NOT getting on the boost, does the car accelerate smoothly through the gears? Did you check all the vacuum hoses? They are the bane of this car, and if they weren't changed recently they will be hard and brittle. Not just a thin ones, but the bigger fat ones that come off the intake manifold and route underneath it. |
+1. Plugs, wires, rotor, distributor cap!
1988 944 turbo |
I think I know what you're talking about because mine did that....It was sort of jumpy on boost? Anyhow I tightened every hose clamp I could find under the hood (sooo many were sooo loose) and it fixed it. Always assumed it was a vac leak.
'87 Guards Red 924S - First Porsche - SOLD 5/21/10 '67 Red VW Beetle - Restored by me and my dad, 2115cc motor. ![]() '87 951 - Silver/blk, full leather interior - LR Chips - 3 bar FPR - LBE '92 Ford F150 - Winter truck '04 Yamaha R6 |
