Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
bleeding the cooling system
After bleeding my cooling system a bunch of times. Is there a way to do it without making a mess? The coolant just goes everywhere.
Old 01-03-2012, 08:25 PM
Super Moderator
nize's Avatar
stick a rag under the bleeder valve when you crack it open? or install the lindsey steam vent, then you'll never have to bleed the coolant again.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 01-04-2012, 10:27 AM
I found that filling the cooling system with the bleeder valve open until the little hole is exposed and leaving the cap off the overflow tank for a while. I had the front wheels off the ground also. Never had to fuss with it after that.
If you already have air in the system, I would idle the engine, and crack the bleeder screw momentarily. Repeat about 4 or 5 times.
Old 01-05-2012, 10:14 AM
