Quick question?
I have a stock 951. With just a intake and cat back exhaust. Not a maf kit. Just filter. If I put a manual boost controller on. I know stofk is 11 psi Can I just crank it to say 14 15 psi and be fine ? I know I need a boost gauge. But do I need a fuel regulator. Or is just cranking the boost fine ?
86' 951 Track car 07' Lifted Lincoln Mark lt "These cars are meant to be driven not polished" |
That Guy
No, you need to use a chip that is meant to run at 14-15psi. You will go lean doing it with just a stock chip.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Ok so I'm buying a Lindsey racing chip. Then a 3 bar fpr. I have an exhaust. Intake filter boost set at 14 -15 psi Is that all I need. If so how much hp am I looking at on that setup. ?? Thanks
Quality
I worry about the future of these cars....
Get it mechanically sound first JB.
85.5 944 NA 5spd - Sold but not forgotten 89 951 Turbo S - Revival in progress...
I suggest intalling a air/fuel ratio gauge before you start messing around, then no matter what you do you'll have an indicator as to what's going on.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
Super Moderator
crank it up for mad power! easy hp gain!
but first read this; Porsche 951 (944 turbo) reference list specifically this part; want to turn the boost up for mad power? read all about the cycle valve here...
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
boost it til it breaks! the fun WILL end. then rebuild it. CORRECTLY! asa far as hp...i'd say 200 to 225
1988 944 turbo |
Ahhahah yeah I need more hppppppppppp
Well with a new racing gasket. What's safe 15 Psi. Or can I push like 17 ish
Also someone told me of I was doing boost and chip not to go with a base oem head gasket set. But to upgrade to the race one. Stock can't hold more then 14 psi.
That's the one I'm buying. Fine?
I'm not sure that's a Racing Head gasket??? I would think that they would be a metal ply with seals and o-rings.
That said, I have a wide fire head gasket, prolly the same one you are buying. I run 17psi. Take time with your torquing procedures. If I remember correctly its like a two day process. Rick
1988 944 turbo |
Head Gaskets ( stock )
Before you boost you should make sure that the engine is solid , even though the engine is in nice running condition the , possibility of the head gasket going is usually a matter of time due to the engine age and just gasket deterioration , Ive rebuilt many of the turbo engines and most of them look the same at the time of inspection. The usuasul pitting or the use of h20 causing gasket deterioration, the best best before you send money on turning up the boost ( chips ,fuel regulators, exhaust , turbo ect. spend the money on the cylinder head and upper gaskets and seals . Its not if it a matter of if, it is when the original gasket will fail. Not to mention rod bearing's oil cooler seals , front seal seals, timing belt ect... These cars are very reliable at boost if you take the time and spend the money on the basics.
Location: In a dumpster behind Albertson's in Los Angeles County
DB Gauges: Air Fuel Ratio Guage There are several listed on ebay now for as low as $167 for the complete kit. One more thing, if you don't want (or can't) make the mounting plate for the gauges, Lindsey sells them too, they fit under the stereo head unit, or you can do an a-pillar mount...Lindsey sells both.
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi Last edited by 89-944NA; 03-14-2012 at 12:05 PM.. |
Maintence before boosting
Additional guages are a great source of info while the car is on the move, but the main priority should be directed on keeping the engine together, most guys out there first thought is turn up the boost and buy as many simple bolt ons as possible due to the ease of instillation or the hype that comes with the differed products. But if you replace the common faliures on the engine first you'll have an engine that you can Boost for a long time forward. Spend your cash on the said basics turn up the boost when the engine is ready for it. ( then you won't be parting out all the goodies that you bolted on like most sell off we are always seeing.
