-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   944 not sparking (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/662972-944-not-sparking.html)
lynns 03-04-2012 03:34 PM
944 not sparking
i have 944 that set in garage for 10 years i changed all the fluids it stated for a moment but i have no fire relays good i have no spark to spark plugs how do check coil
Grandad#3 03-04-2012 04:54 PM
Hi lynns, You can start out using Clark's garage.com Shop Manual at the link below. It would be best if you took the time to read thru it completely as it runs from A - Z. You are in the 951 turbo section. What is your car a 944NA or a 951 turbo and the year?
Clark's Garage Shop Manual Index
Do a SEARCH on here for No Start Checklist.
Cheers,
Larry
MarkRobinson 03-07-2012 07:17 AM
Bosch coils rarely (if ever) fail.
I'd check the connect at the top, rear of your intake manifold for the TPS sensor: if apart, no spark. The connector breaks easily: it's one of the three connections at the rear: just make sure they're all connected. (one's an O2, one's the TPs, forgot what the third is).
Mark
