Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Porsche 944 turbo Starting problem
1986 Porsche 944 turbo, I emptied fuel 3 months ago for the winter storage, now I refueled with 2 gal gas and some gas treatment, I truned key, the car cranked (the starter worked)but no start(the engine did not fired), did not hear the sound of fuel pump, the battery is brend new, what is wrong? need help, thanks!!!
Old 02-25-2012, 07:43 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Check the DME relay, fuel pump could be gummed up, do you have spark? Search this forum for the "No start checklist" and get ready for some fun.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 02-26-2012, 12:36 AM
if the fuel pump is gummed up, how do I fix it?
Thanks, if the fuel pump is gummed up, how do I fix it?
Old 02-26-2012, 01:26 PM
89-944NA's Avatar
some people have had luck soaking them in gas...me, I would just replace it. I think I may have a good spare here, I can check in the morning if you'd like me to.
Semper Fi
Old 02-26-2012, 08:13 PM
Thanks, I heared it too, but how many gal of fuel needed to soak it and make it work if I have a luck? My tank size is about 21 gal, I have put about 4 gal gas into it, do I need put more?
Old 02-29-2012, 01:45 PM
89-944NA's Avatar
You need to remove the pump from the car, carefully cut it out of the rubber soundproofing (be neat, you will need to reuse this), then submerge the pump in fuel and let it sit for a day or two. Then drain the pump, let it air dry and apply power....repeat until you either give up and buy a new one, or it frees up.
Semper Fi
Old 02-29-2012, 10:24 PM
i do not know how to test the DME relay, I just simply replaced it since it was not that expensive, but the engine still not fired up, and I still not heard the sound of the fuel pump. Someone suggested to reflash the computer, but I never heard it and do not know how to do it, what is it anyway?
Old 03-07-2012, 02:52 PM
Get some rags, a fire extinguisher and some beer. Pull the fuel line and crank it. Just for a couple seconds. Ease your pain man!
1988 944 turbo
Old 03-07-2012, 03:11 PM
86 944T w/ the 951-250 kit. Has not run for some months due to alternator and poor charging. Am on 3rd re-built alternator. Replaced both DME and fuel relays. Put in a new battery and several gals of fresh fuel. Engine started immediately, ran for +/- 1-min smoothy then quit. Turns over strong, yet maybe the alternator still is not doing its work. Just won't ignite. A familiar problem for many w/ this car I am sure. Maybe the same solution to this wil resolve yours! Any ideas?
Old 03-15-2012, 08:53 PM
My son who is far more knowledged in this area says it is easy to foul the plugs. he suggests removing and inspecting. Replace if plenty of deposits, maybe replace anyway.
Old 03-15-2012, 08:56 PM
