Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Driveline slack turbo S
Car has 98000 miles and feel some driveline slack when on and off gas. Pulled the inspection plate where the input shaft is to trani and with the clutch engaged in first gear i can spin the input shaft 1/4 turn back and forth. Is that normal? when clutch is engaged i cannot spin the shaft so that rules out the clutch.
ideas?
1989 944 Turbo
Arctic White
1975 911s -new home in denmark
Old 05-04-2012, 06:03 PM
In the Fires of Hell.....
kdjones2000's Avatar
That sounds about normal to me.
Short of having your transaxle rebuilt, I don't expect that there's much you can do about it.
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 05-05-2012, 08:51 AM
