Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
'87 944 turbo timing belt
Have to change the timing belt. 87 944 turbo, has 153000 miles, in decent shape, just bought it. what does it typically cost to do this? what else should be done? Cheap suppleirs? thank you.
Old 05-12-2012, 06:46 PM
Ornery Bastard
Most of the cost on this is labor. I generally figure the proper front of engine service (timing belt, balance shaft belts, rollers, seals, and water pump) as being between $1,500 and $2,000 at a good shop.
Here's a list of the cost of parts and labor for the last time I had it done:
Timing Belt: $32.00
Balance Belt: $82.74
Alternator Belt: $18.40
Power Steering Belt: $7.50
Cam Seal: $10.45
Cam Sleeve Gasket: $1.05
Cam Bolt: $2.05
Small Cam Housing O-ring: $2.55
Large Cam Housing O-ring: $1.55
Upper Cam Balance Shaft Seal: $10.40
Lower Balance Shaft Seal: $14.50
Balance Housing O-ring: $2.65
Seal Sleeve: $29.95
Crank Seal: $15.95
Water Pump O-ring (2x) each: $1.95
Water Pump (rebuilt): $129.95
Labor: 12 hours at $110/hour ($1,320 total)
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 05-12-2012, 07:31 PM
Timing Belt: $32.00
Cam Seal: $10.45
Cam Bolt: $2.05
Seal Sleeve: $29.95
Crank Seal: $15.95
F!
well I thought it would be $1k. where do all those parts come from? I mean, what supplier?
This for a four cylinder?
Old 05-12-2012, 10:13 PM
Originally Posted by jason951crazy View Post
F!
Well I tell you this. As I look over the list, most of those parts are available right here from Pelican. I try to look here first when shopping for parts, due primarily to all the help this Pelican sponsored BBS has given me while wrenching. Even so, as you search around in this BBS, other suppliers will pop up that offer competitively priced high quality stuff.
86 951 blk
Old 05-13-2012, 04:34 AM
I bought the belts and rollers and did not have the water pump done. The parts ran me 100 and the labor was 400 for doing the timing, balance belt, and rollers. I had the auto adjuster which must be set as well. The early cars do not.
Old 05-13-2012, 04:38 AM
968 GUY's Avatar
Jason, you are on a forum sponsored by a supplier of all these parts!
Also there are many threads about changing belts on here. Take a look, maybe it will save you a grand if you have any mechanical ability and the place to do it.
There are many members on here that enjoy helping to work on these cars, might be some close to you.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 05-13-2012, 04:49 AM
968 GUY's Avatar
JAX, I have never been able to figure out what BBS means,...a little help?
Old 05-13-2012, 04:51 AM
Bulletin Board Service
86 951 blk
Old 05-13-2012, 08:02 AM
well thanx. I guess I should see what pelican parts has for this.
Old 05-13-2012, 10:12 PM
ok thank you
Old 05-13-2012, 10:21 PM
I know i'm on a fourum for the parts, but I'm not made of money ok? I understand your point but I'm on a budget! The 30 mpg is why I bought this thing. Thank you
Old 05-13-2012, 10:25 PM
AFM #725
Gawernator's Avatar
That's why you should do the work yourself I'm barely 19 and I can afford my Porsche only because I do everything myself. *minus A/C
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 05-13-2012, 10:39 PM
968 GUY's Avatar
Damn Jason, no insult intended. At the time I sent that, you had 2 posts. Since Pelican is the host, that would be a good place to start, since your question was "where do these parts come from".
Have a nice day!
Old 05-14-2012, 08:07 AM
Super Moderator
nize's Avatar
if you're on a budget and looking for gas economy, why not get a true economy car like a civic? if you still want some performance on a budget why not get a 944?
a 951 will either burn a hole in your wallet, or you'll end up parting the car out due to being priced out of repairs/maintenance, usually both. a 951 is NOT for the limited budget owner if they can't do most/all of their own work.
be realistic.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 05-14-2012, 10:05 AM
Proprietoristicly Refined
John_AZ's Avatar
Jason,
If you do not have service records, you should change the rollers and belts.
Kit for the "updated turbo waterpump" (normally changed by now with 153K)
'87 951 turbo kit
Pelican Parts - Product Information: TB-107-293-K2-M21
Did you have the car inspected before the purchase?
K2- Thanks 968 GUY
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-14-2012, 10:49 AM
Ornery Bastard
F!
Those are the parts costs from the shop I use, straight off my bill. I'm not sure what their source is, but they are generally close to prevailing market price (for equivalent quality parts) in my experience. Yes, this is for a 4-cylinder.
Bear in mind that the timing belt needs to be changed every 30,000 miles or 3 years, whichever comes first. The water pump is generally changed every 60,000 miles. Also, after being changed, the belt needs to be re-tensioned at 1,500 miles and 15,000 miles in between changes. Bear in mind that the water pump is driven off the back of the timing belt, so if the water pump seizes, it can easily destroy the timing belt (and by extension the valves when the belt breaks) so it's important to change the water pump too if you don't know how old the current pump is.
Remember, this was around a $40,000 car in the late 1980's. That's equivalent to a bit more than $80,000 in today's money. The maintenance costs and maintenance frequency demands are going to be commensurate with that market level. If you think the labor is bad for a timing belt, look at the shop times for a clutch change. The book time for the later 944 Turbos, the faster time, is 20 hours.
Also, I don't know many people getting 30mpg on average for a whole tank. While it may touch that at a steady 60 or 65 on a level freeway, I typically observe 23 mpg in mixed driving from mine. And the EPA stickers were 19/27 IIRC.
If you're looking for something fun to drive that's cheap to keep running and good on gas, you're probably better off looking for a Miata.
Old 05-14-2012, 01:13 PM
968 GUY's Avatar
I think he would need the K2 kit since the car is an 87.
Old 05-14-2012, 07:48 PM
