Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
tedg04's Avatar
I know the PO occasionally tracked the car, so I'm going to bite the bullet and do it all. Sucks to spend all that on a car, and then almost all that again in maintenance - at least it will be dialed for use afterwards.
Old 06-20-2012, 09:50 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #21 (permalink)
Ornery Bastard
I sat down once a couple years ago and figured out that I had "bought" my 951 at least three times (that is, in the time I've owned the car I've spent double the purchase price in maintenance, so price + 2x Price = 3x Price). It's probably up to 4x total by now. Still, worth every penny.
Shifting is an art. Learn it, love it, live it.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 06-20-2012, 08:42 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #22 (permalink)
murrayg's Avatar
Any idea why it seems to be always #2 bearing with the problem? Whats different with that crank journal.
Gord.
Scotch Village (near Halifax)
Nova Scotia, Canada
Old 06-21-2012, 01:42 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #23 (permalink)
Super Moderator
nize's Avatar
it has to do with the way the oil pickup/supply works. under extreme high-g prolonged left-turn cornering, all of the oil stays sloshed to the right side, the oil pickup can suck dry/air, which starves the #2 bearing the most.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 06-21-2012, 09:28 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #24 (permalink)
Super Moderator
nize's Avatar
by the way, lindsey (and others) makes a one-way trap door oil pan baffle which prevents this issue. if you're going to remove the oil pan you may as well install this;
OIL PAN BAFFLE LATE 924S / 944 ALL from '87 / 968 at LINDSEY RACING - Your Porsche Performance Parts Center
Old 06-21-2012, 09:32 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #25 (permalink)
tedg04's Avatar
Are you supposed to weld where the red marks are made? So the bottom part of the baffle is what's free to move?
Old 06-21-2012, 09:44 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #26 (permalink)
Super Moderator
nize's Avatar
yes.
Old 06-22-2012, 09:08 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #27 (permalink)
Pulled my Bearings at 160k because the car's history was sketchy, and the Coolant tank looked WAY too clean. The Bearings were fine, [replaced anyway] however, I found many other items that needed attention 'while I was in there'. I'd say wait till Winter then pull the Engine out and get the nasties done all at once, you'll know a lot more by then.
Old 06-27-2012, 03:03 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #28 (permalink)
tedg04's Avatar
I think that is more of the plan now. The car has an appointment just after the 4th to get the tb, water pump, misc oil seals, and cam tower gasket done. I just changed the oil in it, inspected it carefully, and cut open the old filter - no metal (not even shiny flakes as far as I could see). This winter she may get torn into more, but I'm not as concerned about the bottom end now.
Old 06-27-2012, 04:49 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #29 (permalink)
You might want to search gregbbrd on rennlist 928 forum. He has solved the spun bearing issue on 928's which is an even worse issue on the 8 cylinders than the 4's. He had a newly built 6.4 liter stroker on the dyno and was spinning it at over 6K for a lengthy period of time. Suddenluy the engine was spewing engine oil out both banks cylinder head breathers. Its some very interesting reading and he is considered by many to be the 928's best engine builder.
Old 06-27-2012, 06:38 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #30 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
